Pinhole Pentax
Posted 20/03/2017 - 09:47 - Helpful Comment
There will be plenty of videos on YouTube showing the techniques, probably. One way is to make a hole in the centre of the body cap. Then make the pinhole using a very thin sheet of brass, or perhaps even some Aluminium foil. Press a pin through the brass to make a dent, but don't go all the way through. Then sand the dent point until you wear through the metal and make a really tiny, perfect circular hole. Attach the brass pinhole to the body cap, with tape or glue, and the job should be done.
A refinement might be to make a tube to have the pinhole further from the sensor. The distance from the pinhole to the sensor will dictate the focal length/field of view.
Posted 20/03/2017 - 11:46 - Helpful Comment
A long time ago I did (actually in 1977):
This was with a plastic body cap partly cut-out with some aluminium cooking foil stuck to it in which the pinhole was made. Just making a pin hole directly into the plastic might not give a clean edged circle.
I can't remember if that was taken with an ME (which had only just come out) or more likely an ageing ESII.
Posted 21/03/2017 - 10:38
Thanks for the feedback. If I have any success I'll post on here. The idea of different focal length does appeal, maybe two tubes one inside the other. I would tink a light tight seal for the join wouldn't be too big a problem. Off to the drawing board
Posted 22/03/2017 - 00:24
Hmm. Rip the rubber off an old M42 hood and stick the plastic bit that's left to a loo roll core. Screw that into the mount adapter. Make a pin hole affair, as described on a tube that fits the loo roll. Use masking tape around the loo roll to make up any diameter differences and ensure light-tightness. Voila a zoom pin hole :
Posted 22/03/2017 - 13:00
If you want to get really fancy you can buy pinhole body caps from ebay... but half the fun is making it from tin foil, loo roll and sticky tape.
Posted 22/03/2017 - 19:18
i bought one of the ebay ones (more being lazy than fancy), have not used it much yet though.
Posted 25/03/2017 - 08:49 - Helpful Comment
The Q system also has the body cap lens, which will provide images just as blurred as a pinhole will!
Posted 25/03/2017 - 09:22
Looked at a Q system when they more or less first came out (Barrie Forbes had one) and it felt so small and awkward I couldn't consider it.The Q system also has the body cap lens, which will provide images just as blurred as a pinhole will!
As regards blurry images I can and often do get them without really trying. I am now at the stage where I rely on the camera "beep and green lozenge" to tell me when an image is in focus and if that is incorrect it means I'll never ever have a sharp image again even using a tripod and remote Doesn't put me off taking pictures though.
Northumberland
Stan
