Picture Window Pro and RAW files
The source profile is selected under the menu "Workflow" / "Show Color Management Settings". You should see the "Camera Product" as "Pentax istD" (or whatever).
That's where the "camera profile" is. And no, it's not sRGB - it's much wider than that
And it's those source, camera profiles that are the paid-for addons. The Pro version of Capture One allows you to generate your own source profiles and allow very fine, selective colour manipulations. As I've said in other thread you can try other camera profiles (even the wrong ones) - and they'll give completely different responses.
In the second section of that window you'll see the "Output Destination (working space)" - which for your purposes will be "Adobe RGB".
Note that the camera profile is typically a very large colour space, and there'll be a transformation "down" into the output space - whether that's AdobeRGB or (worse) sRGB.
Be aware that your editing application will need to be colour managed as well, and preferably your monitor calibrated and profiled
Thanks for your help,
PygmyT
(And "ProPhoto" colour space for seriously wide colour manipulation in 16-bit TIFF)
Sorry Don, I've only ever spent a day using Knoppix off of a CD, to try to rescue some data of an old PC, but that's perfectly useable as an op, even from the CD. Obviously it'll run a lot faster from the HD.
I think one of the later Redhat variants, or Suse seem to be the most popular from what I've read, but again, I've not used them. I know there are a couple of Linux affionados around here, so hopefully they'll see this thread and jump in.
Liam
My next new PC will run some form of *nix as I am sick to the back teeth of windoze and its built-in "official" spyware http://news.com.com/Microsoft+Heres+how+to+halt+WGA+alerts/2100-7350_3-6088669.html
(and to think I'm a fully paid-up MCSE!)
Liam
20 years
West Sussex,
England
I thought I'd try shooting in AdobeRGB this weekend.
When I came to use C1LE, I got a bit confused about the colour management. I can pick the Camera Model and a Camera Profile, and also a Destination (working) colour space. When you process the image, options include converting to the Destination (working) space. But how does C1LE know which colour space the image was recorded in? It's certainly not embedded in the .PEF file (bit of an omission that). That suggests that the camera profile is really a 'tweaked' colour space (most appications seem to use colour space and profiles interchangeably), say sRGB, and that if you record in AdobeRGB, you must pick that as the Camera Profile.
Have I got this right?
PygmyT
