PENTAX SMC M 135 3.5
Posted 25/01/2012 - 16:53
It's a lot longer than the 50mm, and not much bigger, so it would work as a sort of discrete telephoto for candid portraits, even doggy ones. You can use it for concert shooting if you are fairly near the stage. It's acceptable wide open (in Av mode, which is more convenient) although better stopped down to f5.6. The shots above are lovely and sharp by the way!
Posted 26/01/2012 - 15:31
Thank you for the feed back a bit of an impulsive purchace to be honest not sure if I will use it that often.It's a lot longer than the 50mm, and not much bigger, so it would work as a sort of discrete telephoto for candid portraits, even doggy ones. You can use it for concert shooting if you are fairly near the stage. It's acceptable wide open (in Av mode, which is more convenient) although better stopped down to f5.6. The shots above are lovely and sharp by the way!
Ian
[IMG]http://i23.photobucket.com/albums/b399/philstaff/h2-1.jpg[/IMG]
[IMG]http://i23.photobucket.com/albums/b399/philstaff/h3-1.jpg[/IMG]
[IMG]http://i23.photobucket.com/albums/b399/philstaff/H1-1.jpg[/IMG]
I purchased this lens some time ago but have not realy used it that much and wonderd where it might be best used. I think it might be useful for the odd dog show as a portrait lens but not sure if it offers any more than my 50mm smc m 1.7 to be honest can amy one offer an opinion.
Regards Ian
Ian
