Pentax SMC FA 28-70mm
Posted 24/03/2010 - 20:43
I know nothing of the lens itself, but the zoom range is extraordinarily useful. Great for a walk-about lens.
I have one of more plebeian provenance.
Regards,
Regards,
Best wishes,
Robert Adams
Ernst Hass
Robert Adams
Ernst Hass
Posted 24/03/2010 - 20:49
Hi Andrew, yes I am thinking of going for a lens in the 10-20mm range and teaming it up with this lens. I have the 18-55mm DAL at the moment but I am not that happy with it.
Pentax K-30, Pentax K-m, Pentax 18-55mm DAL, Pentax 50-200mm DAL, Pentax SMC DA 35mm f/2.8, Tamron AF 70-300mm Di LD, Ricoh XR Rikenon 50mm f2, Sigma 18-125mm, Sigma 10-20mm, Pentax FA 50mm 1.7
Posted 24/03/2010 - 21:12
Which one?.....the *2.8 or the F4 ?....I had the F4 version ,a decent enough lens but not spectacular!.It is light weight and plasticy!....
Posted 24/03/2010 - 21:14
I do know that the Pentax-F 35-70mm is very well thought of, although I've yet to try mine properly. It's compact and sharp with a good focal range - equivalent to around 50-105mm on digital.
IIRC the 28-70mm can suffer from separation of the rear elements, which is pretty much terminal. If you decide to go for one then make sure you get a guarantee or can check it carefully before buying.
Posted 24/03/2010 - 21:18
Thanks for both your input, it was the f4 I was looking at, but I may look at the Pentax-F 35-70mm instead now.
Posted 24/03/2010 - 21:34
Yep - looking through the rear element it's pretty obvious as (usually partial) fogging. Pity because it's small, light (OK a bit 'loose') and quite nice optically.IIRC the 28-70mm can suffer from separation of the rear elements, which is pretty much terminal. If you decide to go for one then make sure you get a guarantee or can check it carefully before buying.
Neal
Posted 24/03/2010 - 21:38
I really like mine, but wish it was wider. I want a 24-70; for portraits and parties it's excellent, especially on a small cam, like the k100d.
I don't find the light weight an issue at all - and f4 is really nice to have.
Bret
Bret
my pics: link
Thanks in advance for any advice.
Kind Regards
