Pentax SMC DA XS 40mm f/2.8 accessories
Posted 04/05/2013 - 16:20
I've got a 49mm step up ring attached to min 40mmXS and use a rubber hood and 49mm clip on cap with no problems with vignetting.
Everything Changes
https://www.flickr.com/photos/arleimages/
Posted 05/05/2013 - 21:45
Hi Stephen,
Thanks for the feedback. Looks like that is probably the way to go. I just need to decide which of the several filter sizes my other lenses use I should aim to step up to!
Pentax KF, K-x, 18-55 DAL, 18-250 DA, 50-300 DA, Tamron 10-24 Di II, Pentax DA 40 XS, DA 15, 21 & 35 Ltds, Sigma 170-500 APO, A 50 F2.0, Vivitar PKA 2x converter, Jessops PKA extension tubes. Samsung GX-10, 18-55.
Pentax Q, Q7 + 01 + 02 + 03 + 06, Pentax 110 Super, 50 + 70mm, Soligor 1.7x TC, 110 to Q adapter, Schneider-Kreuznach Tele-Xenar f4.0 150mm, C mount to Q adapter.
Pentax ME Super, MG, K1000, Cosina CS-1 (+auto attachment).
Various PK lenses.
Various PK lenses.
Derby
The lens cap seems rather vulnerable as it is only push fit so I am considering getting an aftermarket clip on type. These are available in the 27mm size but I am wondering if the small size may still make these rather fiddly - has anyone tried one of these caps?
Another possibility is to get a step up ring and use a more standard size such as 49mm. Do other forum members think that the filter threads are strong enough to have a step up ring permanently mounted?
The other advantage of 49mm is that a rubber lens hood could be used - I think that only solid metal or plastic hoods are available in 27mm size. Does anyone know how you can be sure that a hood will not cause vignetting?
Various PK lenses.
