pentax ring flash
Posted 30/01/2011 - 10:56
Lens Adapter rings are available in 49mm, 52mm, 58mm, 67mm filter threads, as well as a macro adapter for PENTAX D-FA series macro lenses.
If your lens filter thread is 55mm diameter, use the 58mm or 67mm adapters with a 55-58mm or 55-67mm (preferred) stepper ring. The larger ring is preferred because a 55-58mm ring could be quite flimsy, the larger one being more robust IMHO.
Using a stepping ring is going to be a lot cheaper than buying a dedicated adapter, even if one does exist.
Posted 30/01/2011 - 11:10
Try warehouse express. I got a stepping ring there recently for a pentax ring light. Not the same threads as yours but they sell all sizes. UP to DOWN. and DOWN to UP. warehouseexpress.com CHEERS Vic.
Posted 31/01/2011 - 09:38 - Helpful Comment
SORRY! I didn't notice his address. but the same answer applies in so much as they are readily available from most good photo stores on line. CHEERS Vic.
Posted 03/02/2011 - 17:05
This is the current datasheet for the AF160FC ringlight. It shows that now, only 3 adapters are included, 49, 52, & 58mm.
That said, if you look at the second page of the same datasheet, it mentions second curtain synch, wireless flash, zoom & swivel reflector, catchlight panel, and a few other capabilities that are not included in this flash.
So I wouldn't believe a word of it if I were you.
It is a very good flash though. I wouldn't be without mine.
Atherton tablelands,
NQ
