Pentax Photo Laboratory Crashing.
Oggy
Posted 21/04/2009 - 22:17 Link
Hi folks - I was just wondering if anyone else was having any problems. I think I have the latest version, 3.61. Typically it will crash after processing a raw and saving it as a jpeg. It does do the save, then frequently crashes and invites me to send an error message.
Posted 21/04/2009 - 22:22 Link
I would suggest you uninstall the program and then re-install. Hopefully then all will be well.
Oggy
Posted 21/04/2009 - 22:30 Link
Thanks John. I'll give it a go. One other favour - could you correct the typo in the title
Posted 21/04/2009 - 22:32 Link
Consider it done!
Oggy
Posted 21/04/2009 - 22:46 Link
You're a gentleman Sir. I noticed it just as I hit the "add comment" button. Thanks.
Oggy
Posted 21/04/2009 - 23:14 Link
I uninstalled it and this time installed the update rather than installing the original then updating it. I got three photos done then it crashed.
Posted 21/04/2009 - 23:34 Link
What we don't know are the details of your computer - do you have enough RAM for the program to run properly? Are you using the right version of Windows? Is there enough space left on your hard drive for Windows to run properly?
I am assuming you have tried the mundane stuff such as restarting the computer?
Lots of questions there, but I'm trying not to make assumptions and these are the sort of things I would be looking at first.
Any of that helpful?
hefty1
Posted 21/04/2009 - 23:38 Link
My copy of PPL has never crashed once so I can't help I'm afraid...
John's point about having enough memory sounds like a good place to start troubleshooting though!
Joining the Q
Oggy
Posted 22/04/2009 - 07:36 Link
It's a fairly standard pc, P4 3GHz with 1.5Gb of ram Windows XP fully updated, No other problems apparent.
shim
Posted 22/04/2009 - 08:19 Link
You may have to reinstall XP, some installations just don't work properly.
It could be a faulty ram module in which case download Memtest and check the memory first. It could also be the capacitors on your motherboard, about the time your CPU was out a lot of faulty Chinese caps were used. Abit were one of the worse affected, you will notice on their current boxes they have a banner on the front saying that only Top Quality Japanese Capacitors are used on this board.
http://www.memtest86.com/
shim
Oggy
Posted 22/04/2009 - 12:31 Link
Given that the complicator is otherwise utterly stable, I doubt it is a hardware or OS problem. PPL does give it quite a bashing, but so does playing Doom3 (:blush and there are no problems with that.
