Pentax Optio i10 Battery change problem
Posted 28/10/2015 - 16:16
With these cameras, when you set the date and time double check that you have scrolled down on the final screen to save changes. If the date and time isn't confirmed it will need constantly re-entering. It's one Pentax menu design element that is actually prone to error.
Posted 28/10/2015 - 22:40
I had this problem with my Pentax Q. I formatted the SD card in the camera and had no trouble since. I hope this works for you.
Posted 29/10/2015 - 09:28
I have done that one a few times before, but not this time. But agree it is a menu design flaw.
Flash: Metz 58, Metz 48
Posted 29/10/2015 - 09:29
Thank you, this is what I had read elsewhere, so will give that a go and post back the result.
South East London
Has anyone else experienced this? Is there a cure?
I have read elsewhere that the SD card can cause this behaviour.
