Pentax M 50mm 1.4
Russ
Posted 26/01/2014 - 14:55 Link
I quite fancy trying the 50mm 1.4 but can't afford the A version. So looking at a few M versions instead, mainly on Ebay but also Ffords have some too.
They are around the £60 mark, which is affordable. Are they worth getting?
cabstar
Posted 26/01/2014 - 15:31 Link
Optically the same as the A version but for a few pounds more why not get the da 50mm which has af, newer optics and coatings?
Concert photography
cbrog
Posted 26/01/2014 - 16:32 Link
Nowt wrong with the manual version - as long as you can find a nice clean one.
They can be found for a bit less than £60...
davidstorm
Posted 26/01/2014 - 19:29 Link
Most definitely 'Yes', the Pentax-M 50mm F1.4 is a fine lens and is one of my personal favourites. If you have a camera with focus peaking (K-01, K-3 etc.) it really shines. Here's an example of one I shot with this lens, wide open at F1.4, the photo is not the best but it shows what the lens is capable of:
Russ
Posted 26/01/2014 - 21:05 Link
Many thanks everyone, just want i needed to know. Can buy one for £60 delivered. Or try my luck on Ebay and save a bit. The one for £60 sounds like a tidy, optically good example. Think i'll just go for that.
kh1234567890
Posted 26/01/2014 - 22:43 Link
£60 is a reasonable price. Alternatively try the Chinon 50mm f1.4. Nearly as good as the Pentax-M 50 f1.4 but usually cheaper.
Russ
Posted 26/01/2014 - 22:50 Link
Funny you should say that. Just been reading about the Chinon and Ricoh XR versions of the 50mm 1.4. And most reviews seemed to say just that, with a lot saying they were just as good. Although searched everywhere and the prices look the same. A couple on Ebay but they are £60 as well. But one does sound mint.
kh1234567890
Posted 26/01/2014 - 23:00 Link
There is little difference between the two if stopped down a bit. The Chinon seems to have a slightly nicer bokeh. At f1.4 the Chinon tends to go a bit too 'dreamy' for my liking. I got both off eBay, attached to old film bodies where the seller thought the body was worth more than the lens.
Sue at f1.4 by kh1234567890, on Flickr
Some test shots with the Chinon and the Pentax.
Edited by kh1234567890: 26/01/2014 - 23:04
Russ
Posted 27/01/2014 - 08:58 Link
Hmm i think i may go about my Ebay search in a different way. Search old Pentax, Chinon and Ricoh film bodies for a bargain lens.
I think i read the Pentax is also a little soft at 1.4 (great for portraits) but really sharpens up at 1.7 >
If i can get any of the three for a bargain price on an old body that will be brilliant.
kh1234567890
Posted 27/01/2014 - 09:19 Link
Watch it or you'll end up counting rubber grip grooves in fuzzy photo listings you'd found on Goofbid and picking up old cameras from dodgy people on dodgy council estates in middle of the night. Been there. Not worth the £20 or £30 that you save.
Posted 27/01/2014 - 09:35 Link
I have bought from Ffordes in the past - good company to deal with in my experience. There does seem to be very few 50 1.4's around at present, but if you can be patient they do come up fairly often
If you expand your search to include Ricoh lenses then do your research on the exact type of lens - there were some Ricoh lenses that had a "pin" that can cause the lens to stick on the camera - I think it was the Ricoh 'P' series.
Ebay can produce the odd bargain, but be prepared for potential problems (fungus, sticky iris, etc) - if your seller has a top record you'll probably be ok, but the hassle you can get with some sellers can be horrendous. It's very rare that I take a chance on Ebay nowadays
Russ
Posted 27/01/2014 - 11:56 Link
Russ
Posted 27/01/2014 - 12:00 Link
I did a quick bit of research and it needs to be the Ricoh XR version, no pin on those.
But i know when you mean about the dodgy listings, most are very sketchy about the condition. Didn't fancy a fungus ridden mess with sticking iris. So was narrowing the search to only those listings that made a point of saying the lens was free from all those ailments. But since you sent me those links i'm thinking of perhaps not using Ebay.
GeorgesM
Posted 27/01/2014 - 12:41 Link
Hi Russ,
I have a very nice copy of M 50 1.4. I tried three different copies and kept this one for its sharpness. I intended to use it for portraits, but it's too short for my taste. PM-me if you are interested.
Regards,
George
malross73
Posted 27/01/2014 - 19:21 Link
I love my M50 1.4 it really is excellent and the quality of the build on these old manuals are stunning. This was shot wide open on my 6mp istdsComment Image
Malcolm
Website link
