Pentax K7 Video Problem
Posted 25/01/2012 - 22:36 Link
I have a Pentax K7 with a 32 GB SanDisk.
Every time I shoot in Movie mode, recording stops after 35 - 38 seconds.
The disk has been formatted. Any suggestions?
Victordinky
Toronto, Canada
steven9761
Posted 25/01/2012 - 22:50 - Helpful Comment Link
Your card is not the problem. At 32Gb, that's more than plenty for adding a movie to. Formatting is not the issue either - I'd suggest checking the battery, to see that it's fully charged, and holding the charge. If the battery is in good condition, I'd consider that either you have accidentally nudged a button to stop shooting, or maybe you need to upfate your firmware?.. After that, get in touch with your local Pentax service centre.
Don
Posted 25/01/2012 - 23:10 - Helpful Comment Link
size of the card is not the most important factor..what is the write speed on this card? class six card or better?
JAK
Posted 25/01/2012 - 23:12 - Helpful Comment Link
Victordinky
Toronto, Canada
1. Is it a 'fast' SanDisk card (eg a class 10) or a slower one. If it's a slower one the camera may not be able to write to it fast enough.
2. Does it do that in all resolutions? It should keep going longer at lower resolutions when it doesn't have so much data to write to the card.
John
Edited by JAK: 25/01/2012 - 23:13
Opethian
Posted 25/01/2012 - 23:17 - Helpful Comment Link
I also would like to support the "speed" issue. Play.com have this which may fix the issue:
http://www.play.com/Electronics/Electronics/4-/19666792/Play-com-32GB-SDHC-Class...
stub
Posted 26/01/2012 - 00:46 Link
Just tried on my K-7.. No problem for 8 mins of video. On an 8gb card speed 10. So has to be speed of card or battery level
Stuart..
Posted 26/01/2012 - 13:41 Link
Thank you for all the replies.
The problem does indeed lie with the speed of the disk.
When I reduced the video quality, there was no problem recording for several minutes.
No I just need to get a faster disk.
Victordinky
