Pentax k5 sensor issue
sebas77
Posted 04/08/2013 - 16:51 Link
it was a long time since last time I had the same issue. So far I thought the problem was related to sensor overheating, in fact usually it is enough to wait some minutes to solve the issue.
However this time I could not take one shot right. I am sure you can understand my frustration.
Edited by sebas77: 04/08/2013 - 16:52
Posted 04/08/2013 - 17:19 Link
I presume you're referring to the reddish stripes bottom right?
If it's a camera fault it's unlikely to go away without a repair, but have you eliminated flare as a possible cause?
sebas77
Posted 04/08/2013 - 17:48 Link
if it was a camera fault should be reproducible right? It is not.
It is not even a flare, because it happened only with the long exposure and the ND filter on.
I have used this ND filter dozen of times and this I have seen this issue just once before.
sebas77
Posted 04/08/2013 - 17:54 Link
here the situation is more severe, as you can see it happens only on the underexposed area
SteveEveritt
Posted 04/08/2013 - 19:05 Link
Are you covering the viewfinder on long exposures to prevent light leakage?
sebas77
Posted 04/08/2013 - 20:00 Link
frak, that's what I forget everytime! Do you think it could be it?
sebas77
Posted 05/08/2013 - 11:00 Link
no one else experienced the same issue? I've already contacted SRS, but I have a strong suspect that Steve is right.
Edited by sebas77: 05/08/2013 - 11:01
Gamka
Posted 05/08/2013 - 11:40 Link
They are very straight but not horizontal. The light is split as if being refracted through a lens or prism.
I don't know if it is sensor ... light leakage through the viewfinder might be possible or maybe a reflection off the filter frame.
Pentaxophile
Posted 05/08/2013 - 13:03 Link
It does look more like light leakage than anything. You didn't mention the long exposure in your original post!
Looking at the angle of the sun, I wonder if direct sun was shining into the viewfinder?
DrOrloff
Posted 05/08/2013 - 14:29 Link
Looking at that I would say there is a 99.9999999999% probability that it is viewfinder light leakage due to the long exposure. Looks just like it, not an issue.
