pentax k5
Posted 17/09/2011 - 13:38
I think if you shoot in green mode, the camera defaults to jpeg, worth a look in the handbook or just try it.
Chris
Posted 17/09/2011 - 14:07
Lookup USER mode in the manual, it will let you use the camera in any mode you want with custom settings.
K7
Tamron SP AF17-50 f2.8 Di II -- SMC Pentax 35mm f/2.4 AL -- SMC Pentax-DA 18-55mm F3.5-5.6 AL WR
SMC Pentax-FA 28-70mm F4 AL
SMC Pentax-M 50mm F1.7 -- SMC Pentax-M 135mm F3.5 -- SMC Pentax-M 200mm F4
Posted 17/09/2011 - 15:42
There is an option memory somewhere, it's not in the custom menu at least.
Posted 17/09/2011 - 16:45
Hi Peter
Not a silly point when you don't know how - I've asked a few 'silly' points on here!
Go to Menu 3 and select 'Raw File Format' and from there select either PEF or DNG. Don't forget to press OK.
Then go to Menu 1 and select 'Format'. Ignore JPEG and select RAW for RAW only or RAW+ if you want both RAW and JPEG. Again press OK.
This is what I have done and RAW is on permanently and is not affected by switching the camera on or off.
Hope that helps
Cheers....John
PS. Not sure if this works on Green or P settings - I tend to use AV.
Hope that helps
Cheers....John
On a dark desert highway, cool Pentax K5 in my hand.
My Kit
K5 & 18-55 Kit lens, K7, Pentax 18-250mm lens, Sigma 10-20mm lens, Sigma 105mm Macro lens, Pentax 50mm 1.7 lens, Cokin P Series Filters
My Kit
Posted 20/09/2011 - 16:40
Hi again everyone! Thanks for all the suggestions-you prompted me to return to the manual, and before I had seen Kentys post.I found there is a 'save all settings' menu item in no.5-it needed more 'o k' pushes than I had first used, but it works. I will keep Kentys way for another time.
Just to say the forum confirmed my likely choice of camera, from reading impressions of contributors-then an inheritance became available, and the Kr became a K5.Am I glad! Low light performance is phenomenal, and the anti-shake. (I like candids).What a great site-I have learned so much!
Peter.
Peter.
