Pentax K200D's disadvantage: viewfinder !
Posted 17/11/2008 - 11:00
Hi gubak,
The K100D has the same self cleaning system (if switched on) as the K200D.
Would you also when you have a moment please update your location details in your profile..
Tel,
Posted 17/11/2008 - 11:04
I'm afraid not, Terry.
The K100D has only a mirror lock function for sensor cleaning. This merely locks the mirror in the up position to allow the use of blowers/sensor swabs. No vibration as in the K200D.
Terry
Terry
Posted 17/11/2008 - 11:23
Hi Terje,
Well why when I turn on Traceys K100D Super does it vibrate like my K20D?
Tel,
Posted 17/11/2008 - 11:38
ttk wrote:
Hi Terje,
The K100D and the K100D Super are different cameras - the "Super" part refers to the fact it has had shake reduction / sensor cleaning added to its spec. It replaced the K100D mid-run.
Hi Terje,
Joining the Q
Posted 17/11/2008 - 11:43
ttk wrote:
Hi gubak,
I hearby stand corrected, and did not wish to give the wrong infoHi gubak,
Thank you Hefty-1..
Tel,
Posted 17/11/2008 - 12:49
hefty1 wrote:
it had sensor cleaning added, but all K100D's have shake reduction.ttk wrote:
Hi Terje,
The K100D and the K100D Super are different cameras - the "Super" part refers to the fact it has had shake reduction / sensor cleaning added to its spec. It replaced the K100D mid-run.Hi Terje,
it was the K110D which didn't.
(is this thread getting complex or what?)
but it does help
but it does help
Posted 17/11/2008 - 13:25
gubak wrote:
The only complaint I have is the viewfinder. Even with the 1.2x adapter I have a hard time manual focusing with my older lenses.
You might like a Katz Eye focusing screen. They are expensive, but hold their value well should you ever sell it or the camera.The only complaint I have is the viewfinder. Even with the 1.2x adapter I have a hard time manual focusing with my older lenses.
See www.katzeyeoptics.com/cat--Pentax-DSLRs--cat_pentax.html
~Pete
Posted 17/11/2008 - 13:59
LOL! I never could keep up! it had sensor cleaning added, but all K100D's have shake reduction.
In which case, I too am happy to stand corrected.
Joining the Q
Posted 18/11/2008 - 07:58
I hear you, and the split focusing screen would help. A friend has a Katz eye and if's very clear and easy to focus manually. He had to take it out and put it back a few times before he got it exactly right though. (he also had the magnifier)
I want to do more of that, so I just ordered a split focus screen, not from Katz-eye, but from an eBay seller in China. The total price including shipping was less than the shipping alone for the Katz-eye, but it could be complete garbage. We'll see!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=220302918301
One blogger used one and was pleased, so I figure I'll take the chance for $23 CDN!
Posted 18/11/2008 - 08:49
they seem to be quite hit and miss, often cut down from film SLR screens so the prism ends up well oversize. Heres hoping you get a good one!
but it does help
but it does help
Posted 18/11/2008 - 11:24
Hi Folks,
Watch this - I'm going to stay ON topic! (I think), (sort of).
I just googled the Katz-eye site and they offer two extra options to the $105.00 standard screen,
I wonder what you think of these:
Optibrite Brightness Enhancement Treatment - $55.00
Pentax AF Area Brackets - $40.00
I for one, would be getting the Katz-eye for manual focusing, so shouldn't need the AF brackets?
Would the brightness option be some sort of SMC like coating?
Appreciate any and all advice!
Cheers,
Cheers,
Mac from Montreal
Posted 18/11/2008 - 13:34
Depending on which one it is, it might fit fine or it might not fit properly. In either case, it's likely to not look as good as a Katzeye and will black-out more easily.I want to do more of that, so I just ordered a split focus screen, not from Katz-eye, but from an eBay seller in China. The total price including shipping was less than the shipping alone for the Katz-eye, but it could be complete garbage. We'll see!
I'm basing this on my own experience and on what I've read from many other users. It may not have been much money, but you will have wasted it if you end up getting a Katz Eye anyway - which is what I did.
Anyone else reading this who fancies a split-image screen, please take my advice and just get a Katz Eye straight away. In the unlikely event of not liking it, you will be able to get nearly all your money back by selling it on eBay or to a fellow forum member.
~Pete
Posted 18/11/2008 - 13:44
Let alone manual-focusing, you can happily live without the AF brackets even for auto-focusing (even when using the off-centre points), so certainly don't have that option if you want a clean look.I wonder what you think of these:
I have the Optibrite option. I'm not sure what this is physically, but it seems OK and a good idea to have the screen as bright as possible. Any difference with the metering is so slight that I haven't even noticed. That is with centre-weighted and matrix.
One serious disadvantage (for some) that we should mention, is that spot metering is affected and may not work well or properly at all because of the split-image circle (depends on the lens to some extent). Personally, I decided this was a price worth paying.
~Pete
Posted 18/11/2008 - 20:22
Thanks Pete!
With a K110D pentaMIRROR, I agree that the brighter the better.
Never thought of the spot metering being affected, but you make a very good point. Did you move next to Center Weighted?
Agree that the AF marks are not needed - nor the extra cost.
Should I buy two? One with, and one without the coating, to do a side-by-side brightness comparison? I'll ask the Katz-eye folk if they can show me examples - might be less costly!
I'll let you know how that goes.
Cheers,
Cheers,
Mac from Montreal
Excellent value for the money. Great camera for the beginner. Lots of excellent good quality lenses available for reasonable prices on Ebay.
