Pentax K100D or 200D
Posted 19/05/2015 - 11:08 - Helpful Comment
K200D gets my vote of the 2 it is a superb camera.
However you may wish to look at some of the newer models as as good as the 200d is, things have progressed.
I would be tempted to think about K7 or newer.
Good luck!
Good luck!
Posted 19/05/2015 - 11:25 - Helpful Comment
It depends on the budget but you might find a fairly inexpensive K-5. In one sense, the later the model the better as things do move on.
Posted 19/05/2015 - 11:36
Thanks, I'm pleased with the fairly rapid response.
Yes, it was somewhat remiss of me to provide a 'Ball Park Figure' for whT I'm able to spend. I guess £80 camera, £100 lens.
Posted 19/05/2015 - 11:38
That's low, but £180 should find something worthwhile. Try SRS and see if they have suitable used kit, and also of course eBay. You could also put an ad here in the Classified Ads section of the forum.
Posted 19/05/2015 - 11:54 - Helpful Comment
Pointing a listing out on forum will help to make sure of that.
Posted 19/05/2015 - 11:58
Yes, appreciate your sentiments
Remove asap
Remove asap
Posted 19/05/2015 - 12:03
Job done, thanks.
I'm an amateur as you can see. I assumed my reply was to you only, but I now see NO messaging for 1st 30 days on joining etc.
Thanks again.
Thanks again.
Posted 19/05/2015 - 15:40 - Helpful Comment
Between those two I see no reason to choose the K100D. You might well find something newer for a similar price though, such as a K-r (though it lacks the top LCD, weather sealing, battery grip option and robust build quality).
Posted 19/05/2015 - 16:45 - Helpful Comment
yo may just find a k10 which is a very good work horse
Posted 19/05/2015 - 16:48
thanks for the advice and information Jonathan-Mac.
Yes, with the kind help of other Forum Users I've been guided to K-5 or K-7, or Ks-1, but yes the K200D is the better choice.
Unfortunately my funds are somewhat limited at the moment but I might be lucky to push for an Ebay deal on the K-5/7, but I suspect the K200D is more affordable.
Chris Lynch
Chris Lynch
Posted 19/05/2015 - 19:30
Chris Lynch
You wont go wrong with a K200D Chris, I loved mine, wish I had kept it to be honest.
Chris Lynch
Posted 19/05/2015 - 21:55
Sorry for the delay, many thanks Stu 62, and once again Andrew.
Chris
Chris
11 years
I just wanted to tap your wealth of knowledge and experience etc.
I'm just getting back into photography, and so intend purchasing a Pentax (my first) primarily for Motor Sport, and the usual 'sightseeing' experiences etc. I've been encouraged by colleagues to consider the K100 or 200 DSLR's with a single 18-200mm lens. As I'm not a rich man I'm inclined to search for a good Used camera.
Do you reckon I'd be better looking at alternative models or not?
I'd appreciate your help.
Many thanks.
Chris Lynch
