Pentax is so slow... is this normal..??
First there is the switch on time as the camera initialises. When the shutter is part depressed the lens focuses and the exposure is set. Finally, the shutter relases on a full pressure. If you "snatch" straight into the full travel of the shutter release, this process will seem to take quite a while.
Having said that, apart from action shots, the delay can be coped with and, as users of large format cameras will tell you, slowing down is no bad thing!
What can effect this is light. The lag is low in good conditions, but in low light conditions the shutter lag seems to be worse.
You can use the pre-focus by holding the shutter release half way, and this will significantly reduce the time taken to capture. As always, have a good play and experiment in a variety of conditions before parting with your hard earned dosh!!
24 years
Animals are not ours to wear
