Pentax HDRs
Do you have the EXIF Data?
Like the way the colours come out in this one.
Kind regards
SmutjeUK
It's nice to be nice!
http://www.flickr.com/photos/michaelcullendesign/5417103684/meta/
I'm not sure about the vignetting at the top to be honest, I think it's just a side-effect of the postprocessing in Photomatix; sometimes you have to play with the smoothing slider to eliminate dark borders around the image; I uploaded this in a bit of a hurry and missed it, and I'm too lazy to re-upload a fixed version
Here's another shot from the same day:
EXIF data: http://www.flickr.com/photos/michaelcullendesign/5418560018/meta/
Kind regards
SmutjeUK
http://www.flickr.com/photos/michaelcullendesign/sets/72157625495062657/
I did get a few nice shots, like these:
Bigger
Bigger
Bigger
But I found that I was coming back with far too many shots with either blown highlights or no shadow detail, despite the bracketing. I realised that I needed more of an EV difference, so I went out with some M42 lenses and tried bracketing manually with aperture control.
These are the results:
http://www.flickr.com/photos/michaelcullendesign/sets/72157625817069935/
Bigger
Bigger
Bigger
In my opinion, having a wider range of exposure gives you a lot more tolerance in each particular scene, and gives you more room for creative control during the postprocessing stage. Once you've got the shots, it's all down to your processing in Photomatix / HDR Efex Pro, etc.
After the successes with the M42 lenses, I decided I needed a body which let me AEB at +/- 2EV, as I like to shoot handheld, and AEB is crucial for doing HDRs handheld, and started looking for the K100D, which I managed to get for a good price from a member here
Very good!
Kind regards
SmutjeUK
One day I just like to come just a little close to what you can do with a DSLR and I am a happy man.
Many thanks for sharing those great shots with us.
Kind regards
SmutjeUK
I found the biggest challenge was learning how to visualise scenes differently with an HDR workflow in mind; on top of thinking about the composition as you would with any shot, you also have to consider what scenes will have the most impact when processed as HDR... extremes of light and dark, which would normally be a warning sign when taking a "normal" photo are in fact desirable qualities for HDR photography, as long as you can meter the baseline shot correctly (something I still struggle with sometimes!).
The next thing I'll be experimenting with (if I ever get around to it) is film HDR; I managed to pick up an EOS 500N body for £5 and an M42 adapter, so at some point I'll head out with some fine-grained negative film and use AEB to capture some 3-shot bracketed sequences, scan and process them as HDR. Should, theoretically, yield even greater dynamic range than with a DSLR
Very nice results from the K100, and interesting to see the others - the brand is kind of irrelevent, but glad to hear the Pentax offers better AEB options! Stick with Pentax as the K7 and K5 offer up to 5 AEB shots up to 2EV apart.... that should be enough for any HDR fan!
And yeah, I agree that it's very easy to go OTT with HDR; at the moment I'm trying to use it to bring out shadow and highlight detail without making shots seem too surreal; a good example of this would be the Owell Bridge shot above which, although taken on my Alpha, is my personal favourite so far.
I think these days there's often a backlash at any mention of the term HDR - especially in film circles - due to the proliferation of the OTT "grunge" shots that Photomatix became well-known for producing in its first couple of versions; Version 4, which I use, actually has too smoothing modes, the newer of which gives you more control and allows you to obtain more "natural" looking shots. Often when looking at HDR shots, you need to look at them side-by-side with the original to see just exactly what benefits processing as HDR has brought to the photo
mdc
Member
UK
To kick things off, here's a driveway
