pentax f 35-70
reso
Posted 16/07/2010 - 10:34 Link
i have got one that has a little oil leak inside and it shows in the photos are they ease to take apart and clean advice please
womble
Posted 16/07/2010 - 11:13 Link
Zooms are generally quite difficult to work on unless you really know what you are doing, and AF lenses even more so. The F35-70 is a lovely little lens but not that rare and fairly cheap. Unless it is essentially free I'd keep looking for another example. Often the best place to find them is attached to the front of an SF7/SFX/SFXn.
Best wishes, Kris.
hefty1
Posted 16/07/2010 - 11:32 Link
Zoom lenses, as Kris says, tend to be a nightmare to service and the cost of a professional doing the job would likely be several times the value of the lens. There comes a point when some jobs just aren't worth doing.
Joining the Q
Clarky
Posted 16/07/2010 - 11:41 Link
I can tell you from experience the F series 35-70 is not a lens you would want to tackle, I spent a couple of days trying to get it back together properly, and that's with taking notes and pics as I was going, it's in a zillion pieces inside a plastic box now, and that's where it will be staying I'm afraid
Very frustrating and not worth the effort IMO.
Camera:|K-7|
reso
Posted 16/07/2010 - 11:50 Link
thanks for the info now a paper weight
Edited by reso: 16/07/2010 - 11:52
Dangermouse
Posted 16/07/2010 - 13:35 Link
I opened an old K 28-50mm zoom last week (had a fungus problem, still has some as I couldn't get the rear element group apart but it's nothing like as bad as it was). The main problem was resetting infinity focus - I resorted to using a TV transmitter mast about 4 miles away and adjusting until that was in focus with the lens set to infinity.
I would not, however, even try an AF zoom. I once attempted to fix a spares or repair 28-80mm which was a complete disaster. On the plus side, it provided all the Power Zoom switch parts that were missing from an otherwise perfect example of the same lens bought a few months later!
The F 35-70mm is a lovely thing, especially on a K-m or K-x. It's probably the best sensibly priced compact AF lens you can buy. Mine came attached to an SFX for £30, which I thought was pretty reasonable. Just don't get it confused with the F 35-80mm which is horrible!
