Pentax Digital Camera Utility Help
mcut
Posted 18/11/2011 - 14:53 Link
I know a lot of people will be using other editing programs but wonder if someone can assist me with the following questions about the K5 supplied software:-
1. if i have the DNG file on my screen and simply add it to process queue without any alterations and then hit ok from image process queue will it create a jpeg exactly as the camera would have created a jpeg, and
2. my understanding (which may be subject to error) of when a camera creates a jpeg from a raw file is that one of the things that it does is create a tone curve, why when i open a jpeg in PDCU is the curve flat, when i process a DNG is a tone curve being created at all or is that one of the things i am supposed to be doing myself as a matter of routine.
3. Is "extract jpeg" used when you have made alterations to just provide a preview image of what the final jpeg should look like
4. if i have a histogram where there is no data at one end, should i be dragging the arrows in the exposure pane curve to cause the histogram to have data spread evenly. (this question may not make sense!) i have used other software that allows levels adjustments, dragging the sliders to the black and white points. what should i be doing in PDCU instead?
5. i am assuming i will find a set of adjustments that i will like to be generally applied to my photos and then save those adjustments as a parameter?
Mark
mcut
Posted 20/11/2011 - 12:43 Link
Bump. Anyone?
ChrisA
Posted 20/11/2011 - 13:08 Link
Just as with the levels control in PhotoShop, whether you move the sliders in to boost the brights and darken the darks is entirely down to you - if enhancing the contrast like that is what you want, then fine, but it shouldn't be a default action regardless of the content.
There are plenty of low contrast images that are supposed to be that way.
ChrisA
Posted 20/11/2011 - 13:11 Link
Not 100% sure, but it does appear that if I load an image into the utility, it comes in with the same settings for contrast, sharpness etc as the camera is set to.
So I expect that if you develop it to JPG without any additional changes, it would be as you say.
mcut
Posted 21/11/2011 - 09:45 Link
thanks chris.
anybody able to assist with my questions 2 and 5
