Pentax DA* 50-135 SDM
Posted 01/07/2023 - 13:36
Put it on the camera body, cap on.
Hold the AF button to force the lens to focus while at the same time turn the focusing ring back and forth. You should see the AF light turn on while this happens.
After a while, there's a chance the SDM will become free and so the lens will start to focus correctly.
All the gear with no idea
Posted 01/07/2023 - 13:48
Tryed both ways and still no joy
Posted 01/07/2023 - 16:48
Before you try either of the first two suggestions, get a small screwdriver that fits the screwdrive slot in the end of the lens, then keep rotating the screwdriver to drive the lens focus from end to end. Do this for a few minutes. Then try suggestions above. Wakes my dozy lens up every time.
Posted 01/07/2023 - 17:28
Thanks for all the help
its packed up ready to post on monday for a screwdrive convershion
Posted 01/07/2023 - 18:04
Reso, can you give me details of who you're getting to do the conversion, please, should I need it too?
Posted 01/07/2023 - 21:44
yes this would be very helpful
Posted 04/07/2023 - 18:18
This method seems to also click when you manually focus the lens at a distant object. The lens seems to try and push for that last bit of precise focus, freeing the motor.
worcestershire
