Pentax bellows
Posted 17/05/2019 - 14:54
I do like a nice bit of kit, and this certainly qualifies.
I guess you can also copy negative film and create positive images in Photoshop or similar.
Posted 17/05/2019 - 15:04
Nice, I use the same bellows for my macro shooting. The stop should be easy to replace.
Nice box too.
Nice box too.
Posted 17/05/2019 - 15:16
The coffee cup holder's missing!
The slide copier comes with a film-strip holder. I'm travelling at the moment but I'll have a play when I get back.
Posted 17/05/2019 - 16:30
If you look at the bottom of the second image you can see two, but only for espressos...
Posted 17/05/2019 - 19:30
Looking at my A Set it occurs to me that the front main beam stop on your set may have been transferred to the slide copier?
Roger
Roger
Posted 18/05/2019 - 01:04
No, there are two of them on the slide copier and they are both decidedly "captive" to the unit. I just checked mine.
One thing that gets overlooked with this is the connector for the cable release. If you are using a tripod and an auto lens with a DSLR you can focus wide open and then push the connector by hand to stop down and then twist the knurled ring. It locks it ! Release the shutter with an IR remote and you get no shake at all.
Posted 18/05/2019 - 15:01
Jammy Begger. I've been looking for something si
milar for a long time now. I'm not desperate but if I see one I might just be tempted.
CHEERS Vic.
CHEERS Vic.
Posted 18/05/2019 - 15:45
For slide copies with APS-C cameras you need a lens of around 60-70mm. I used to use a Nikkor EL 63mm. FF should work with a 50mm.
Hertfordshire,
mostly.
Pentax bellows (1) par Kris Lockyear, on ipernity
Pentax bellows (2) par Kris Lockyear, on ipernity
Pentax bellows (3) par Kris Lockyear, on ipernity
Pentax bellows (4) par Kris Lockyear, on ipernity
Pentax bellows (5) par Kris Lockyear, on ipernity
