pentax af 500ftz
Posted 05/09/2017 - 17:37
Depends what you mean by any good. It is quite a powerful flash and it works wirelessly on the K5. The only drawback is, it is manual only on the K5 ( TTL ). It was ideal for this event as the distance between flash and subject was constant give or take a foot or two LINK
John
John
Posted 05/09/2017 - 18:40
Great set of photos what sort of range has it got wirelessly and does the wireless flash have to face the camera?
Posted 05/09/2017 - 19:37
In a confined space ie bedroom the range with camera & flash in line & both pointing forward is about 10ft. Outside with the camera pointing at the front of the flash the range is about 30ft (tested at 19:25 with a fairly clear sky )
I hope that helps
John
I hope that helps
John
Posted 05/09/2017 - 20:10
Great helped a lot thanks very much
Posted 01/12/2017 - 18:15
Lo que más me gustan son todos los tipos de fósiles ya sean bonitos o no
worcestershire
How good is this flash used on a k5 ? can i use it wireless? info please
