Pentax 540FGZ II HELP
Posted 19/03/2014 - 14:12
Just try it and see, but I expect the 645D will have a slower flash synch speed because of the much larger shutter. What that is will be detailed in the operating instructions.
Posted 19/03/2014 - 18:43
Thanks John. I will try it and see. I checked the operating instructions and it states the flash sync as 1/125.Just try it and see, but I expect the 645D will have a slower flash synch speed because of the much larger shutter. What that is will be detailed in the operating instructions.
Kind regards
Alasdair
Posted 19/03/2014 - 19:34
alasdairfyfe wrote:
I have a 55mm D FA 645 1:2.8 Lens. The flash unit sets the zoom at 43mm automatically? Should this not be 55mm? or do I need to make manual adjustment ?
I've never checked to see what the AF540FGZ does on APS-C cameras whether it takes into account the crop factor, but since the sensor is larger than 36x24mm the 55 will effectively be a wide-angle, probably wider than 43mm in 35mm terms so I would refer to the manuals or wisdom on the forums to see whether the flash goes wide enough if it indicates 43mm
AKA Welshwizard/PWynneJ
Posted 19/03/2014 - 22:37
ilovesaabs wrote:
I've never checked to see what the AF540FGZ does on APS-C cameras whether it takes into account the crop factor, but since the sensor is larger than 36x24mm the 55 will effectively be a wide-angle, probably wider than 43mm in 35mm terms so I would refer to the manuals or wisdom on the forums to see whether the flash goes wide enough if it indicates 43mmI have a 55mm D FA 645 1:2.8 Lens. The flash unit sets the zoom at 43mm automatically? Should this not be 55mm? or do I need to make manual adjustment ?
Kind regards
Posted 20/03/2014 - 09:00
On my old (long gone) film 645 the flash speed was 60th. and the lens was 3to2 ratio with 35mm. Or in other words a standard 75mm lens was the same as a 50mm lens on 35mm camera therefore a 55mm lens is the same as a 36.6666666666666666666mm lens on a 35mm camera.
CHEERS Vic.
CHEERS Vic.
Posted 20/03/2014 - 18:41
CHEERS Vic.
Thanks Vic. That is really helpful.On my old (long gone) film 645 the flash speed was 60th. and the lens was 3to2 ratio with 35mm. Or in other words a standard 75mm lens was the same as a 50mm lens on 35mm camera therefore a 55mm lens is the same as a 36.6666666666666666666mm lens on a 35mm camera.
CHEERS Vic.
Kind regards
Posted 21/03/2014 - 13:10
The flash sync speed is 125th. If the flash camera combination is setting at 1/50 then one or both are set to P
As far as handheld shots are concerned the sync speed is irrelevant largely, the effective exposure is the duration of the flash which could be 1/10000sec.
Posted 23/03/2014 - 20:25
CHEERS Vic.
Actually the 55mm equates to around 67mm in 35mm terms. The 645D has a 44x33mm sensor. The 55mm is optimised for this size and not the traditional 645 format.
CHEERS Vic.
Posted 24/03/2014 - 09:14
OK Mr monkey. As you can see I was referring to an old film 645. If things are different on a 645D then so be it. I bow to your superior knowledge of the modern version of a great camera. Film or Digital.
Alasdair. Just enjoy your nice new toy.
CHEERS Vic.
CHEERS Vic.
Posted 24/03/2014 - 21:04
Thanks Vic. I will certainly enjoy playing with it.
Kind regards
Kind regards
Does the Flash unit set the correct speed that can be use for handheld on the 645D? The flash has set shutter at 1/50 on my 645D or do I need to increase the shutter speed. Previously I have always worked on the speed being 1/60 as the slowest speed for handheld shots?
