Pentax 18-35mm FAJ
Anonymous
Posted 11/11/2003 - 19:36 Link
Bought this lens as a part of the *ist D package. I appreciate that it is not expensive but the fall-off in edge definition, particularly on the right of all pictures, is very marked. Is this normal, or do I have a duff lens?
Camera, however, is brilliant!
Anonymous
Posted 21/11/2003 - 08:22 Link
I am now considering buying a S/H Pentax 17-28mm f/3.5-4.5 F series lens.
What is the difference between F & FA? Will a F series lens work with the *ist D?
Posted 21/11/2003 - 21:36 Link
This lens is the fisheye zoom, which goes from a wild and wacky fisheye effect at the short ens to a fairly normal 28mm. Should be interesting...
All modern Pentax autofocus lenses should be OK with your new camera.
Anonymous
Posted 22/11/2003 - 07:43 Link
Thanks for replying.
In terms of the proportion and distortion of the final image would there be any difference between the Pentax 18-35 FA-J supplied with the *ist D and the Pentax 17-28 fish eye lens I am thinking of buying?
Whether it be 17mm or 18mm at the short end, the image on the sensor will be almost identical. Is my thinking correct?
Posted 22/11/2003 - 21:05 Link
There will be an enormous difference - the 18-35 is intended as a standard lens for the digital sensor, giving an effect similar to a 28-80 on a standard film SLR.
The 17-28 allows all the straight lines to bend outwards at the 17mm end (barrel distortion) to give a fisheye effect. This effect comes more under control as you zoom towards 28mm. Now on a CCD, which is smaller the lens will give an angle of view more like a 28-80 again, but presumably with masses of distortion at the wide end. I can't begin to guess whether this will be a desireable effect or not - if you can find a dealer with a lens I would try it on the *istD and check out the effect before buying.
Looking at it the other way round - what effect are you trying to achieve with your new lens purchase? If you can define that then the way to go might suggest itself better.
Best wishes,
Anonymous
Posted 23/11/2003 - 12:39 Link
The reason for considering the fish-eye lens is that I am not happy with the "standard" 18-35 FA-J lens. The one I had was very, very soft at the right hand edge at almost any apertures. I am waiting for it to be replaced. If the replacement has the same problem, then I need another lens of a similar range.
The Sigma 17-35 is very expensive; the Sigma 15-30 even more so.
I cannot even find a prime lens around 20mm f/2.8 that would meet my need.
Is there no alternative to the 18-35 FA-J? I live in hope that its replacement will be OK ... but I have my doubts.[/b]
Posted 23/11/2003 - 15:08 Link
Hi Malcolm,
I've not tried the 18-35 but even at its low price it should not be sharp at one side and not the other. It could be that an element is displaced or perhaps the CCD in the camera body is not aligned properly - either way a replacement lens will give you the answers.
There are two high quality Pentax lenses you could try: the 20mm f2.8 or the 20-35mm f4 zoom. I've noticed the zoom being advertised by a dealer in AP at around £320 which is a fantastic price. If you are happy with a more telephoto effect then the 24-90mm is also an excellent lens, crisper than the 18-35 according to Pentax User magazine.
Do let us know how the replacement lens works out.
Best wishes
Anonymous
Posted 23/11/2003 - 16:25 Link
I do not think that the CCD is out of alignment as the camera produces excellent results from a Pentax FA 28mm f/2.8 and a Sigma EX 50mm macro.
It is because I have these two other lenses that a 20mm would complete the trio, giving the 35mm equivalents of 30mm, 42mm and 75mm. Just perfect!
Hpowever, I'll give the replacement Pentax 18-35 another go before jumping. All the alternatives seem so expensive!
Anonymous
Posted 02/12/2003 - 06:38 Link
I have taken a long time to come to any conclusion.
I tried a Sigma 17-35 ... it was soft overall, but particularly at the edges.
I tried a Sigma 20mm f/1.8 ... it was VERY soft at the righthand edge only at f/2.8 (in very low ligh conditions, 1/15 sec exposure).
By the way, all these lenses have been from CameraWorld in London. I bought the camera from this firm and it could not have done more to help - Jason was the point of contact. All I paid was the return postage each time I sent a lens back. They paid there own costs.
Yesterday they delivered another of the original lens, the Pentax 18-35mm FA-J. Again, it was OK in the centre (compared with a Pentax f/2. as similar apertures, but very, very soft at the edges.
THEN I FOCUSSED IT MANUALLY. Both at infinity and in closeups the centre definition rose to match the Pentax 28mm and the edge definition was only a whisker away. (The Pentax 28mm seems to work fine in both auto and manual modes ... very only very minor differences ... but manual focussing still gives the slightly better results.)
What is wrong? Is it the chip in all 18-35mm lenses, or is it that the camera finds it hard to focus with only f/4 to work with and when in low light situations (which tey were).
What do others think? At the moment I am using the FA-J but have turned off the autofocus. What a waste on an otherwise super camera.
Posted 02/12/2003 - 20:13 Link
Ironically, autofocus will be happiest when there is enough light and we could happily focus manually anyway!
I only use autofocus in portrait sessions where it is fantastic to focus swiftly on the eyes, quickly recompose and shoot. Much more reliable than manual focusing.
For everything else, I use manual focus.
Anonymous
Posted 03/12/2003 - 10:49 Link
I have just agreed to buy a used "mint" Pentax A 20mm f/2.8 which should arrive in the next week, or so. I'll post my findings.
It is the manual focus version so I will not be in any dilemma about the method of focusing!
Anonymous
Posted 08/12/2003 - 13:58 Link
The lens I have just bought (s/h Pentax 20mm A f/2. works fine with brilliant, crisp images except for two things ...
1. When in "Green" mode it always creates over-exposed images. Setting the camera to minus one stop creates well exposed images every time. This is no real hassel, but should there be a difference in exposure settings between lenses?
2. The lens does not tell the camera that its focal length is 20mm. The data associated with the photograph displays "----mm" and the Lens Name is "A Lens". So the camera seems to assume that the 20mm lens is a telephoto lens and always selects the highest possible shutter speed. For instance, when using the flash it always choses 1/150 sec., whereas when using the Pentax 18-35 it usually choses 1/30 or 1/45 for most shots.
Are these concerns normal when using older "A" manual focus lenses with a modern camera, or should the lens go to Pentax for a service?
Thanks for all the help.
Malcolm
Anonymous
Posted 09/12/2003 - 08:38 Link
Oooops!
I now read in the Instruction Book that 1/150sec is the norm for flash photos with an "A" type lens.
Still does not answer when the "Green" setting always over exposes by about one stop when using the "A" lens.
Malcolm Riches
Posted 13/12/2003 - 08:38 Link
I'm no longer a Guest! I've joined!
Malcolm Riches
Posted 20/12/2003 - 09:18 Link
I am answering my own post with an update on exposure problems using a Pentax A 20mm f/2.8 lens with an *ist D - it was always overexposing by one stop. This seems to be because I had made ISO400 my norm for the winter (habit!).
I am proving that if I set the ISO rating to anything other than the default 200, I get exposure problems with my manual (A) lens. I have no such problems with my FA lenses at any ISO rating. I was blaming a wonderful lens when the problem lies with the camera!
Is there a firmware glitch in that manual lenses have to be used only with the default modes because they are not sending any "signals" to the camera body? This appears to be my situation.
