Pentax 17-70 Quick-Shift Manual Focus?
salixarbour
Posted 12/03/2009 - 11:47 Link
Hello, all.
I've just taken delivery of the SMC Pentax DA 17-70 f4 AL[IF] SDM lens.
(I need a tea-break after writing that).
I read a review stating:
"Thanks to a Quick-Shift system, manual focus override is instantly possible in Single-Shot AF mode".
My lens doesn't appear to have any quick-shift switch.
Please tell me, am I being silly or was the review report inaccurate?
Regards.
Alan Lowe-Jones.
Camera: K20D.
Lenses: Pentax DA* 55mm f1.4 SDM, Pentax DA* 16-50 SDM, Pentax 18-250 SMC DA, Pentax-M 50mm f1.7, Sigma 70-300 F4-5.6 DG macro.
Flash: Pentax AF360.
bforbes
Posted 12/03/2009 - 11:52 Link
it does not have a switch i think it means you can manual focus without switching the camera to manual. that's what happens on my k10
Posted 12/03/2009 - 12:12 Link
It means you can turn the focus ring manually even when the lens and body are in "AF" mode.
So, you can half-press and get the camera to focus, then hold while you adjust the focus ring manually
salixarbour
Posted 12/03/2009 - 12:33 Link
Many thanks, Matt/Barrie.
Thanks for that info. I does seem an odd thing to perhaps want to do, then again, maybe that's my inexperience showing.
I read that the turn/travel in the manual focus ring is so short/sensitive that it makes manual focusing difficult anyway.
Having read the reviews, I was aware of that, so not really a problem.
Matt, thanks for pointing me in the 17-70 direction in the first place...a couple of weeks ago in another thread. just one question though:
My manual focus ring is quite light to the touch/easy to turn/more so than my 18-250. Does that seem about right?
Regards.
Alan.
Camera: K20D.
Posted 12/03/2009 - 12:36 Link
It sounds right, so I wouldn't worry.
The Quick Shift system is actually very useful when fine tuning macro shots. I used to use manual focus only for close up shots, but now use AF and adjust as required manually. It is more efficient for still life subjects.
Clarky
Posted 12/03/2009 - 12:49 Link
Could'nt agree more John
Camera:|K-7|
bforbes
Posted 12/03/2009 - 13:41 Link
Yeah it's OK. mine feels as if it's not moving anything it's so light
salixarbour
Posted 12/03/2009 - 13:58 Link
Thanks to all.
That makes me feel better.
I did so want a little MF/AF switch though!
Regards.
Alan.
Camera: K20D.
Posted 12/03/2009 - 15:02 Link
Two options:
1) Switch to MF on the body
2) Use the custom menu to turn off "Focus on half-press" and just use the dedicated "AF" button on the back.
I use option 2 - kind of "Auto focus on demand". Much prefer it to anything else
beakynet
Posted 12/03/2009 - 15:45 Link
You need the DA* 16-50 for that!
Flash: Metz 58, Metz 48
RichardDay
Posted 16/03/2009 - 10:23 Link
Regards.
Alan.
The 18-250 being a Tamron design, doen't have quick shift.
Having quick shift is a great feature, as it enables you to "tweak" the focus point after AF or (especially if you use the rear AF button only), you can manually focus without forcing the AF motor gear chain, and then use AF to "trim" to the final position, this is a very quick way to achieve focus lock very quickly. It's much more noticeable on lenses with a large focus rotation angle.
Having recently acquired a Tamron 70-200 f2.8 (no quick shift), I do miss that particular ability, as sometimes the AF isn't quick enough or "misses" and has to complete a full cycle before re-capturing the AF lock, especially with a TC fitted as they slow down the AF speed.
The 17-70, being SDM only and having a small focus rotation angle, is a very quick focussing lens, unlike some other SDM lenses which are fairly slow, noticeably the new DA*55 and the DA*50-135 which is no speed demon, again due to a large focus rotation angle.
Many of the screw drive AF lenses have large focus rotation angles, I'm specifically thinking of the D-FA macros and the DA 55-300, those lenses benefit considerably from quick shift + AF trim operation.
Richard Day
Profile - link - (click on About for equipment profile) - My Flickr site - link
