Pentax 'Anti-Shake' let me down
Posted 21/05/2015 - 17:48
Hi Peter,
1/50th second at 150mm may be a bit of a stretch. I assume you had to put the focal length in first for the Shake reduction given the use of a manual lens. Is it possible you entered the wrong length intended, as its a zoom lens?
In the first the central character looks sharper but all seems out of focus in second two.
Posted 21/05/2015 - 18:26
150 x 1.5 = 225, so the minimum shutter speed should be 1/250s. Three stops advantage means we might expect to get away with 1/30s with SR on, so 1/50s is OK, but only just.
Posted 21/05/2015 - 18:40
I didn't think it was possible to use an 'M' lens in Av mode ... ??
Posted 21/05/2015 - 18:42
It is but only with a fully open aperture.
Posted 21/05/2015 - 18:59
I see, thanks ... Is it possible that in this configuration the SR would not activate, even though the shutter opened? How was the shutter speed set without any stop-down ... Just trying to think through the possibilities that could have disabled the SR.
Posted 21/05/2015 - 19:43
Hi Peter,
Looks to be camera shake at about 40 deg. If they are important Focus Magic could recover quite a bit. Do it in 2 processes...
1st fix Motion Blur at 40 deg. Distance Value 4
2nd Fix Focus at a Blur Width of 3
The FREE version allows 8 goes (I think)
http://www.focusmagic.com/
Posted 21/05/2015 - 21:44
Algernon wrote:
Hi Peter,
It seems to just heavily pixelate the image.Hi Peter,
1/50s might be enough at 150mm but I wouldn't rely on it. 1/50s isn't fast enough to avoid motion blur in moving people though.
Posted 21/05/2015 - 22:33
This basically.1/50s might be enough at 150mm but I wouldn't rely on it. 1/50s isn't fast enough to avoid motion blur in moving people though.
Shake Reduction allows you to hold the camera for longer shutter times, but it doesn't stop objects moving in the frame during that period.
These don't seem to be shake related problems to be honest, but more a consequence of having too long a shutter speed for the speed of the action in the frame. 1/200 of second would be more suitable for instance, and higher still if you want to ensure there is no movement blur. You'll need a faster lens, or a higher ISO to achieve this.
Just went through the exact same thing with photos from the kids cross country sports run, which needed more ISO and less shutter speed to catch the kids.
Posted 22/05/2015 - 02:40
To my eyes the static objects are just as soft as the potentially moving ones so I don't think its subject movement.
Posted 22/05/2015 - 06:54
The handshake one seems rock solid in the middle and blurry as you head away from this?
Posted 22/05/2015 - 08:12
Just a thought. Did you have the camera on a tripod? If so then the SR should be turned off as it counteracts its self.
CHEERS Vic.
CHEERS Vic.
Posted 22/05/2015 - 08:50
Thanks for all your 'Expert Input' -- well NO I didn't use a tripod as the Public Gallery was packed -- I have done pics from there before and got better results last year -- I will try a PRIME 150mm f4 SMC Takumar with the Screw-Bayonet adapter setting full aperture . Usually when I use an 'M' fit lens on my K10D I find it DOES stop down OK -- I usually have to use some + exposure compensation though -- I have no trouble in better light using that lens for local Press work as here ----
These were 'stopped down' OK and used in the Yellow Advertiser Havering Edition this week.
Posted 23/05/2015 - 08:54
How nIce Thanks for all your 'Expert Input'
Well then the following opinion is for anyone else wanting to try this:
It's a combination of things by the looks of it. Basically almost everything is wrong.
Way too slow shutter.
Manual zoom, can't have SR set accurately. SR doesn't work as well at the long end anyway.
Wide open lens focus user error given poor light in viewfinder?
incidentally, a manual lens won't automatically stop down during the exposure; you explicitly set it and get a reading before the shot. Or you work with it wide open.
Posted 23/05/2015 - 09:53
I cannot understand what members say on this site that 'M' series lenses will not 'stop down' and can be used only at full aperture -- I have no probs seeing the aperture stop down if I use 'AV' or 'M' exposure mode -- all my 'M' lenses stop down OK -- the aperture activating thing works. Here is the actual 75-150mm SMC Pentax-M lens set to f11 and photographed during a time exposure I set of 13 seconds on my K10D -- it has stopped down OK ---
21 years
Brentwood Essex (UK)
