PELI CASE (Model 1450) for sale.
duncanM
Posted 05/02/2012 - 19:53 Link
This case is no longer needed by me. It is in what I consider pretty good used condition- see photos. Cosmetically it is not perfect, but otherwise it is completely undamaged.
These are just about the last word in tough watertight crushproof and dust proof cases, manufactured to military specs, and specially suitable for storing camera kit. The official interior dimensions are 376x263x152mm and the exterior dimensions 406x330x174mm. The lid is fitted with convoluted foam, and the main compartment with “Pick N Pluck” high density foam, pre-cut so that it can be pulled out bit by bit to accommodate bodies, lenses etc, as needed .
The gaps seen in the photos were made by me and exactly fit a Pentax K5 body plus 3 DA limited lenses (the 15mm, 40mm, & 70mm)and a 4th item- can't remember what These gaps could be enlarged as necessary to fit other gear, (and of course complete new precut foam blocks can be bought if you want to start again from scratch).
These are very expensive new, and second-hand usually go on Ebay for £50-£60 or more , but just in case any forum member would like it, I’ll offer it here first, for £35 (plus delivery at cost- probably: £5-£10:, and if you want to arrange it yourself, or me to use a particular delivery service, that’s fine by me).
If you want more info, try here.
[IMG]http://i1033.photobucket.com/albums/a418/duncan7777/Pelicase001.jpg[/IMG]
[IMG]http://i1033.photobucket.com/albums/a418/duncan7777/Pelicase002.jpg[/IMG]
[IMG]http://i1033.photobucket.com/albums/a418/duncan7777/Pelicase004.jpg[/IMG]
[IMG]http://i1033.photobucket.com/albums/a418/duncan7777/Pelicase003.jpg[/IMG]
[IMG]http://i1033.photobucket.com/albums/a418/duncan7777/Pelicase005.jpg[/IMG]
T140
Posted 06/02/2012 - 12:41 Link
Hi where in the south of scotland, i would be interested in this, if you are local i could pick it up.
Nobody is perfect, but being Scottish is a start
duncanM
Posted 06/02/2012 - 13:24 Link
T140- reply sent by P.M.
duncanM
Posted 07/02/2012 - 15:26 Link
Case sold to T140. (Thanks Ian).
T140
Posted 13/02/2012 - 20:36 Link
Arrived on Sat, thanks again
Ian
duncanM
Posted 13/02/2012 - 22:07 Link
Thanks for letting me know it has arrived, and I hope you'll find it very useful. It should certainly keep your gear safe
