PEF's not opening
Bobbinalorry
Posted 13/01/2010 - 22:36 Link
Hello again folks,
I am unable to open PEF files in Photoshop CS3 I am using Windows 7. Jpegs open but not Pef's. Any idea's please?
Best Regards, Larry.
All the gear & no idea.
Posted 13/01/2010 - 22:56 Link
Is your RAW converter updated to recognise your PEF files? Updates are needed for every new camera model as the PEF files are camera specific.
Bobbinalorry
Posted 14/01/2010 - 09:20 Link
Hi John,Thank's for help; I am not sure, I did go to the Pentax site and check for and download updates I found,So I THINK I am up to date but not certain. How do I check please?
Posted 14/01/2010 - 09:31 Link
You need the Adobe site for updates to the Adobe Camera RAW, which will included the latest pentax cameras shortly after they were released.
Unlocker
Posted 14/01/2010 - 09:33 Link
Are you using a K-7?
If so CS3 won't work as Adobe want you to use CS4!
Maybe use the Pentax software to convert PEF to DNG for photoshop use if that is the case?
Anvh
Posted 14/01/2010 - 10:00 Link
Or shoot in DNG.
CS3 works with the K20D/K200D & K-m and earlier cameras but the K-X and the K-7 don't work.
Here is a link to all Photoshop updates
http://www.adobe.com/support/downloads/product.jsp?product=39&platform=Windows
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 14/01/2010 - 10:05
Bobbinalorry
Posted 14/01/2010 - 15:57 Link
Hi Unlocker
No, I'm using K20D. Pray tell how I go about changing PEF to DNG?
Bobbinalorry
Posted 14/01/2010 - 16:01 Link
Anvh wrote:
Or shoot in DNG.
Greetings Anvh
I usually do shoot DNG but somehow twiddled some knobs and used PEF my mistake for a while; I swapped back to DNG as soon as I realised.
Thanks for the link, I'll give it a go
Anvh
Posted 14/01/2010 - 17:12 Link
Ah a K20D, just install this one and it will work link
Stefan
K10D, K5
AF-540FGZ
Bobbinalorry
Posted 14/01/2010 - 18:24 Link
Yep, done that but no joy! Is it just me/ I'm getting a complex here, I think maybe Adobe hates me !??!
Anvh
Posted 14/01/2010 - 18:26 Link
Hmmm that should have done the trick for the K20D and Photoshop CS3.
What happens when you try to open a PEF file?
Stefan
K10D, K5
AF-540FGZ
Bobbinalorry
Posted 14/01/2010 - 18:49 Link
Reply to Anvh,
A window opens telling me 'Could not complete request because it is not the right document '
Anvh
Posted 14/01/2010 - 19:42 Link
I always start yelling at my screen if it does that but it has never worked
The adobe camera raw update should have done the trick...
Could you do this for me?
In CS3 window go to Help>System Info you will get a list and if it's correct you can see copy, if you do that do you want to paste it here in a comment.
We can then see what plug-ins are installed and such inside CS3.
Stefan
K10D, K5
AF-540FGZ
Bobbinalorry
Posted 14/01/2010 - 21:43 Link
Dear Anvh,
I have found and tried (see below) and it works
"You could try installing FastPicture Viewer Codec pack. It does support Windows 7 x64 and PEF. I am using that on my system. And it's free."
Fast Picture Viewer | WIC RAW Codec Pack for Windows 7, Vista and XP
In future I shall be sure to use only RAW and not PEF's
However, a BIG thank you for taking the bother to help
Lynton
Posted 14/01/2010 - 21:52 Link
CS3 works fine with my K20d and PEF or DNG. Have version 4.7 of camera updater........... anythign higher and it keels over.
