Patterns
sueriley
Posted 25/04/2009 - 20:46 Link
This is the roof of the Botanical Gardens in Wales. I have turned this into mono by using calculations.
[IMG]http://i240.photobucket.com/albums/ff250/johnriley1uk/Patterns.jpg[/IMG]
Sue
fatspider
Posted 25/04/2009 - 21:06 Link
Is it me or is the bottom of the border bent
Nice one Sue, and welcome to the forum.
My PPG link
My Flckr link
paulyrichard
Posted 25/04/2009 - 21:16 Link
The bottom is perfectly straight, its an optical illusion. It happened with the top edge on my 'Street Sleeper' image due to the linear effect of the bars in the photo.
Excellent photo by the way.
fatspider
Posted 25/04/2009 - 21:23 Link
I was being facetious, my eyes aren't that bad.
My PPG link
My Flckr link
shim
Posted 26/04/2009 - 08:46 Link
Just goes to show that you can't believe what you see. It's standard practice in building to camber any beams, because straight one's look like they are sagging.
shim
George Lazarette
Posted 28/04/2009 - 00:19 Link
shim
An old trick indeed; the Athenians modified the width of the columns of the Parthenon for the same reason. The Egyptians probably did the same.
Karl
Posted 28/04/2009 - 20:23 Link
Brilliant image Sue , what are the calculations you speak of?
https://pentaxphotogallery.com" target="_blank">https://pentaxphotogallery.com/images/black_link_small.jpg" alt="See my photos featured in the PENTAX Photogallery" />
bforbes
Posted 28/04/2009 - 23:50 Link
shim
Rolls Royce used to make the radiator grill headers concave so they looked flat. So i'm told, never actually measured one!! Striking picture by the way
sueriley
Posted 29/04/2009 - 00:32 Link
Hi Karl,Calculations is a way to turn colour images into B/W by using channels. This gives you more choice in the final image.
To find calculations go to IMAGE-CALCULATIONS (fifth one down) Because you only have one image open your source 1 & source 2 will be fixed as the same image. In the SOURCE 1 channel box make sure RED is selected, In SOURCE 2 you can play with the other channels to get the effect you like. You can then change the BLENDING mode, again to your taste. When you are happy with your B/W photo select NEW DOCUMENT in the RESULTS box, click OK, & you have a multi channel image. To make this a normal file go to IMAGE-MODE-GREYSCALE & save as required.
Hope this sounds OK & you have fun trying this method.
Sue
bforbes
Posted 29/04/2009 - 00:43 Link
Sorry Sue which Prog. are we talking about?
Posted 29/04/2009 - 07:07 Link
Sue was talking about Photoshop in general and CS2 in particular, but versions from 7 onwards offer this feature.
nickh
Posted 29/04/2009 - 17:55 Link
If you scroll up and down using the mouse wheel whilst looking at the image it looks like it's moving! hope that's not just me who can see that. Interesting shot, I like the patterns. I have a shot a bit like that whilst the sun was setting lighting all the beams orange - but didn't compose it as well as you did!
gartmore
Posted 29/04/2009 - 19:07 Link
George Lazarette wrote:
shim
Entasis
K
