Patience, precision, pins 'n' needles...
trickletreat
Posted 11/07/2011 - 13:13 Link
...that will be macro then!
Picked up a tamron 90mm macro from the classifieds at the weekend, so firstly, thanks John, and here as promised are a few initial attempts today. This is going to be harder than I thought, what dof?
Any help or advice would be welcome. Do people use tripods, lens hoods[seemed to upset some bugs], focus rails etc.
These were handheld, sat on a caravan step, with elbows set on knees, and still it was really hard to focus!
[IMG]http://img.photobucket.com/albums/v425/inamini/IMGP1293.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v425/inamini/IMGP1076.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v425/inamini/IMGP1083.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v425/inamini/IMGP1075.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v425/inamini/IMGP1064.jpg[/IMG]
Thanks for looking.
Nigel
womble
Posted 11/07/2011 - 14:01 Link
For bugs tripods, rails etc., are not much use as the insects tend to go walkies before you are ready. For flowers etc., a tripod can be a great help. The main issue is light which often means using flash of some form or another. I have been experimenting with a Pringles tube attached to my AF500FTZ flash with muslin as a diffuser.
K.
trickletreat
Posted 11/07/2011 - 14:08 Link
K.
I saw your recent post and great results. As I only have the on board flash, I will see if I can rig something up to get the light past the end of the lens!
I can see the draw back of the tripod with bugs, unless you choose one flower and wait...
Nigel
Mannesty
Posted 11/07/2011 - 14:19 Link
Welcome to the miniature world that is - macrophotography.
"What DOF?" - to get a deeper DOF, you'll know that you need to use the smaller apertures, f11, f16, and even smaller, but that reduces the amount of light hitting the sensor. To achieve those smaller apertures you need to increase the light hitting the sensor some other way. Longer shutter speeds are really out of the question, especially for hand held shots. Higher ISO's introduce noise to the extent that the image is unusable. The answer - light, light, and more light.
Dedicated macro ring flashes can be expensive. Whatever you chose, you need to chose something, either a ring flash or a hot-shoe flash. The on-board flash simply will not be powerful enough.
For a first attempt, I think your images are very good indeed. The aphid stuck in the web is good by itself, it would have been even better had you waited for the incy wincy spider to show up.
Edited by Mannesty: 11/07/2011 - 14:21
womble
Posted 11/07/2011 - 15:02 Link
The Pringles tube idea was originally used with an on-board flash (the idea wasn't mine) as it helps get the relatively weak flash past the end of the lens. I found that I needed much more ooomph hence the AF500FTZ. You can use older Pentax dumb flashes providing you can change the power output (1/1, 1/2, 1/4 etc). I use the flashes on manual if shooting that way.
Macro is one area where digital is so much easier than film as you can experiment to your heart's content, and fire off a fair number of images until you get one in focus. I haven't tried focus stacking yet....
Most of all, HAVE FUN!
K.
trickletreat
Posted 11/07/2011 - 15:51 Link
Some great info and ideas, I have just quickly made a flash tube by covering some card in tin foil, then folded it into a tube, with a periscope end, to overhang the lens. I have not tried it on a bug, but here is the difference it makes on a detailed object.
1. without light tube, and macro lens extended.
[IMG]http://img.photobucket.com/albums/v425/inamini/IMGP1307.jpg[/IMG]
2. with light tube.
[IMG]http://img.photobucket.com/albums/v425/inamini/IMGP1308.jpg[/IMG]
Now to find some bugs, and use a smaller aperture!
Nigel
trickletreat
Posted 11/07/2011 - 18:10 Link
Well I found some bugs...this mornings first attempt was in strong sunlight, these werte taken with it being more overcast. This morning I took over 300 images, and only kept 20, this afternoon, I took 50ish, and kept half, with many needing only slight cropping.
1. The light tube
[IMG]http://img.photobucket.com/albums/v425/inamini/IMGP1367.jpg[/IMG]
2.[IMG]http://img.photobucket.com/albums/v425/inamini/IMGP1313.jpg[/IMG]
3.[IMG]http://img.photobucket.com/albums/v425/inamini/IMGP1346.jpg[/IMG]
Number three really showed me that the advice given re aperture and extra light, makes a huge difference...f/32 1/160s iso 200
Nigel
SteveEveritt
Posted 11/07/2011 - 20:27 Link
I managed to pick up a DOI ring flash from ebay for £50.
And this was the result ... link
Hand held, camera set on X-sync f16 and "catch in focus" enabled. Simply move very very slowly towards your subject and just before it comes into focus hold your breath, inch (mm) closer and once in focus the shutter fires automatically, a wonderful tool.
Welcome to the obsession that is macro shooting.
Edited by SteveEveritt: 11/07/2011 - 20:28
Mannesty
Posted 11/07/2011 - 20:57 Link
Now you can see that extremes of aperture do not produce the best results.
Whilst I'm sure you are pleased with these results, and justifiably as it's only your second attempt, the images are not sharp. DOF is good, thanks to the small aperture, but try f8, f11, or f16 next time.
It's perfectly acceptable to have parts of the image out of focus (OOF) as long as the parts that should be sharp (the eyes), are really sharp.
Edited by Mannesty: 11/07/2011 - 20:59
Mannesty
Posted 11/07/2011 - 20:58 Link
SteveEveritt wrote:
I managed to pick up a DOI ring flash ...
DOI? It's not an acronym I'm familiar with.
Algernon
Posted 11/07/2011 - 21:16 Link
DOI were a supplier in the 70's did some decent
tele-coverters and filters. Don't know if it's the
same company or not.
Mannesty
Posted 11/07/2011 - 21:36 Link
Algernon wrote:
DOI were a supplier in the 70's did some decent tele-coverters and filters. Don't know if it's the
Thanks for that. Looks like it might be the same company. I found them on the 'net now.
