Padstow
Posted 23/09/2018 - 23:08
2 &3 work extremely well. You were blessed with a dramatic sky and the light it cast.
Posted 24/09/2018 - 07:22
At some places, the light effects turned out so effective! Nice set of pictures.
Posted 24/09/2018 - 10:24
Good use of the lighting Rob - a lovely mixture of gold, grey and blue set the mood nicely for this set
Posted 24/09/2018 - 12:28
Great set of photos.. The quality of the Pentax lens sticks out a mile... Well it should really. Shouldn't it...
Stuart..
Stuart..
Posted 24/09/2018 - 13:53
Thanks all, Stub yes the Sigma surprised me by being very sharp but there is CA and also the colours are very flat but that can be dealt with to an extent in processing. Roll on the new 70-200 f4!
Posted 24/09/2018 - 20:44
I like No2 where the light just brushes the buildings beautifully, and the composition is nicely balanced. The last one (although it has dull light) has depth because of the sort of compressed look caused by the distance, and the eye is tempted to zigzag through the scene.
I would suggest you looked at the processing & boosted contrast a bit, plus they look a little soft, perhaps extra sharpening would help?
Posted 24/09/2018 - 23:29
Thanks McGregni, Following your comments I took another look and yes they don't look as sharp as they should and whilst I have improved them a bit I think a few factors have caused this. Firstly, the light was quite dim but with bright patches so I was being careful to avoid blown highlights and underexposed slightly. At the time I didn't judge a grad filter to be necessary but was wrong and found I needed to apply one in PP, and raising the exposure introduced some noise which I hadn't noticed before. And finally I reduced the pdfs to import into PU which degraded the sharpness a bit more. These aren't meant as excuses but lessons for me to remember for next time, so McGregni your comments have been most constructive.
Posted 25/09/2018 - 07:12
pdfs ?And finally I reduced the pdfs to import into PU which degraded the sharpness a bit more.
John
Posted 25/09/2018 - 07:38
DOIK wrote:
John
Sorry, yes JPEGs of course, it was rather late!
John
Posted 25/09/2018 - 15:21
Hi Rob, just in case you're not aware, when reducing image size for the web you should include an automatic algorithm that preserves quality. If you use a dedicated tool for sizing (eg Photoshop's "Save For Web") this will include choices for the scaling method. The one to choose is "bicubic sharper". This should produce an image that keeps the look and sharpness of the original
One other thing. .... If you are working straight from your full sized K1 files the scaling might just be too great, and causing quality loss. Even with my K7 I always produce a full size JPEG first, with quality number 11 .... That produces a file around 5-7mb (reduced from the RAW size of 12-14mb).Then with that JPEG open in Photoshop I carry out the further process of Save for Web.
So it's a two stage process, not jumping immediately from a big camera file.
I keep both JPEGs .... The bigger one for archiving and to use if wanting to get the photo printed, and the smaller one for web display, phones and iPads etc.
I set an output size in the save for web dialogue of 65% ( so chopping 35% of the resolution. .... You would have to chop a lot more) ...
Then with the quality slider I aim for a file size of around 500-700Kb ...I have not seen any visible quality loss with these figures for any of my photos when displayed on any screen.
Posted 25/09/2018 - 16:08
Oh, right, I assumed that converting from a full jpeg to a smaller one would degrade more than from a source RAW file so thanks I will look at what Lightroom offers.
Posted 26/09/2018 - 05:15
Amazing set of images. In some images, the light effect is looking beautiful.
Posted 26/09/2018 - 20:38
Nice set Rob... super light throughout, and particularly like the framing/composition of the final one...
Best
Best
Posted 26/09/2018 - 21:51
That's some light
12 years
Warwickshire
And a bit later on:
And finally, from the same position with the Sigma 70-300mm f4-5.6 macro at 300mm:
