P50 apeture blonde moment?
Posted 19/01/2010 - 09:01
The first thing to try is cleaning the camera and lens contacts with a soft cloth. Then reseat the lens and see if the problem has cleared.
Posted 19/01/2010 - 16:25
Thanks John, yep all contacts cleaned. This happens with another lens also so I will presume its a body thing as opposed to the lenses.
So I am right to think that when set to Auto/Manual when the shutter is half pressed if I select different stops the speed display in the finder should change, which at the moment it doesn't. If I stop down with the DOF preview and select different stops the speeds change.
This is my first P series so got me a little baffled or just a ill body.
Thank you
Thank you
S Raff
Posted 19/01/2010 - 17:15
Yes. Suppose we use Av, as the aperture is changed the speed should change to compensate. You change the aperture by turning the aperture ring. Set the aperture ring to "A" and now the shutter speed can be set and the aperture will change with varying light levels, and of course also if the shutter speed is altered.
Set the aperture ring to A and the body to AUTO and you are in program mode.
And so on. You're not forgetting that the aperture ring is an active item on these cameras by any chance?
Posted 19/01/2010 - 21:00
possibly, how do you mean 'active'?You're not forgetting that the aperture ring is an active item on these cameras by any chance?
S Raff
Posted 19/01/2010 - 21:09
sraff wrote:
To change aperture in AV/manual you actually use the aperture ring, not something on the camera body like the K10/20 etc.Quote:
K.
Posted 19/01/2010 - 21:50
yes thats what I'm doing, but as I change the aperture ring setting (say from f2.8 to f4 or f16) the shutter speed does not change (unless I use the DOF preview when the shutter speeds then move accordingly).
So do we all agree its the camera and not me? and any ideas on a home fix or just put up with it?
Thank you
Thank you
S Raff
Posted 19/01/2010 - 22:36
Try another lens perhaps and make sure it is indeed the camera. Then either use the modes that work, get it fixed, or, probably buy another from eBay for less than the cost of a repair.
Posted 19/01/2010 - 23:21
Got me another ME Super on its way so not too fussed, the P50 will have a nice spot in the display cabinet with all my other delights.
Thanks for the help, hopefully the ME Super is in better order, sold a beauty a while back and regretted it since.
S Raff
North Devon
Thanks for any help,
Stephen
