Oxeye daisy sunset
cardiffgareth
Posted 01/07/2021 - 17:32 Link
Taken the same night as the other thread!
2 images expsoure blended into 1 - one for foreground exposure and focus and the other for sky exposure and focus.
Pentax K1 & Irix 15mm
Wild Flowers Sunset by Gareth Williams, on Flickr
Sry
Posted 01/07/2021 - 22:32 - Helpful Comment Link
Keep up the technical workout Gareth, it's working!
cardiffgareth
Posted 05/07/2021 - 09:18 Link
Thanks Serge
Posted 05/07/2021 - 22:12 Link
Looks great.
For someone who doesn't understand complicated software, how is it done?
My page on Photocrowd
cardiffgareth
Posted 05/07/2021 - 23:10 Link
Thanks David.
Have everything in manual, use live view and set exposure for the foreground. Zoom in and manual focus. Depending on the scene as a rule I usually focus 1/3 into the scene. 2 second timer and take the shot. Then adjust your exposure to suit the sky, live view zoom in again and focus on the distance. Again take the shot.
Now you have 2 images, one focused on the foreground correctly exposed and one on the sky, also correctly exposed and focused.
Make your edits in LR and then click ctrl so both images are selected. Then right click and select edit in PS as layers.
Once loaded into PS, the top layer I like to have as the sky layer. You can click, hold and drag to rearrange the layers. Then press Alt and press the mask button to make a filled in layer mask that's filled in. Then select a soft hardness brush and paint the one layer in over the other.
Once you're happy, flatten the image and press save to bring the new edited Tiff file back into LR.
If you have something that could have moved or you didn't use a tripod between image 2 and 2 then when the two images come into PS as layers then click on one, press shift and click the other. Then go to edit and auto align layers.
Hope this helps! I can do a YouTube video also if easier
Lubbyman
Posted 06/07/2021 - 08:55 - Helpful Comment Link
A good picture of an unpromising subject.
But whatever happened to hyperfocal distance and ND grad filters??
Posted 06/07/2021 - 21:49 - Helpful Comment Link
Thank you Gareth. I was afraid it might involve dark magic with incomprehensible software. All I have ever got out of Photoshop is a chequerboard pattern that I can't do anything with. It doesn't work any more anyway since Adobe changed everything so it is now a non-problem.
Flan
Posted 06/07/2021 - 22:05 - Helpful Comment Link
Great info Gareth,
I only have rawtherappe as editing software
There might be something similar in rawtherappe , not sure
Thanks for sharing your learning of editing techniques
Wish you the best on your photography adventures
I hope but also I’m certain you will make it professionally
Edited by Flan: 06/07/2021 - 22:07
cardiffgareth
Posted 06/07/2021 - 23:17 Link
Thanks all, appreciate the comments.
Steve, wanted to make sure it was as sharp as it could be so by focusing at different areas meant nowt was soft! The difference between the dark area and light in the sky was more than my 3 stop ND could handle so I exposure bracketed instead.
Dave, its all dark magic I tell you which requires much chanting.
Flan, as long as you can have layers and layer masks then you're away. To shoot professionally as my job would be the dream
Flan
Posted 06/07/2021 - 23:44 - Helpful Comment Link
Layers must remember
Time for me to catch up
👍 Gareth
RobL
Posted 07/07/2021 - 07:28 - Helpful Comment Link
Hi Gareth, great result, I suppose another option would be to get the exposures right in LR then just focus stack in PS, letting the software sort out that awkward area where the two photos merge in the middle. However if anything is moving like trees or the sea then your method is best.
Lubbyman, hyperfocal distance is something I only managed to get right once, when a pro stood over me, pointed to a spot seemingly far too close and told me to focus on that! It helped having a wide angle lens as well.
cardiffgareth
Posted 08/07/2021 - 18:15 Link
Thanks both
