Over exposed
Posted 13/02/2008 - 01:45
Sorry, with JPG, not much you can do after the fact. You might get a little if it isn't truly blown out, but this appears well beyond fixing.
Posted 13/02/2008 - 07:49
Nor with RAW. When it's gone, it's gone.
Posted 14/02/2008 - 12:09
I am sure that using older lenses (K mount at least) will make the camera revert to centre weighted metering, this is fine if your aware of it and know how to compensate under tricky lighting conditions.
Your swan pic would have taxed even multi segment metering, definately a case for bracketing your shots, even more so if using the Cosina.
Jackfield,
Shropshire
