OT. USB hub question
Posted 16/04/2009 - 07:43
All back via the PC.
Even the USB ports in your PC may be on an internal hub which can slow down the overall transfer rate.
Posted 16/04/2009 - 14:08
Thanks.All back via the PC.
Posted 16/04/2009 - 14:22
USB isn't intelligent enough for this.
If you have firewire drives it could work because firefire devices can talk to each other directly.
Tamron Lenses: 28-200
Takumar Lenses: SMC 55 1.8
Posted 17/04/2009 - 21:42
Sadly, I only have one Firewire drive; the others are all USB.
Next time, I'll look at Firewire.
Posted 17/04/2009 - 21:55
A normal external hard drive with a Firewire port will still require a PC to do anything.
~Pete
22 years
London
If copying files from one drive to another (both attached to the PC via the hub), does all the data have to be transferred up to the PC, then down again to the other drive, or are these things intelligent enough to simply transfer the data straight through the hub?
