Optio 5S1 - manual shutter speed
Posted 19/04/2005 - 23:46
I've had a quick glance at the manual, and I don't think you can as there is no manual mode. The nearest you can achieve is to set a mode that will give you the effect you want. So, if you want the highest shutter speed applicable then set sport mode. If you want a small aperture set landscape mode. If you want a large aperture set portrait mode, and so on.
There are lots of modes, some downright bizarre - would you believe food mode (lets you take appetising pictures of prepared food!)
Posted 20/04/2005 - 19:03
Thanks John.
What happened is I misinterpreted a review I read on Amazon. Some chap said: "The only difference I can see between my optio 555 and the S5i are the advanced operational facilities, such as manual control of shutter speed and aperture". Not knowing anything about the 555, I assumed wrongly that he meant the S5i had the manual control... I realize now it's the other way round...
Never mind, I'm only a little disappointed. My S5i is great (and a lot cuter & cheaper than the 555!)
21 years
