Optio 33LF - SD memory card format problem
Posted 01/01/2006 - 17:29
Are you using fresh batteries?
Posted 03/01/2006 - 12:09
Yes. A brand new CR-V3.
Posted 03/01/2006 - 12:10
Sorry, that was me - I'm not used to being able to post without being logged in!
Posted 24/04/2006 - 10:25
I have the similar problem. My 33LF is just out of warranty. I can turn it on, take one shot then it turns off all by itself. I have to wait a few minutes before it will work again, then the process repeats itself. Anyone else had this problem? It has new batteries.
Regards.
Regards.
Posted 24/04/2006 - 20:40
I would suggest the old standby of loading the latest firmware, which you should be able to download from the Pentax web site http://www.pentax.co.jp/english/support/download_digital.html
However, if it powered off while the firmware upgrade was taking place you might end up with a seriously dead camera. If you have a mains adapter it might be worth a try, otherwise I'd take it to my nearest Pentax service center.
20 years
I inserted a brand new 256MB SD memory card. Carefully following the instructions, I tried to format it. I took this through to the point where my camera LCD said it was 'formatting' and then *poof* the screen went black and my camera turned itself off.
I tried it several times. I tried it with a new 16MB SD card, in case the 256MB had been too big? Yet all to no avail.
Can anyone possibly tell me what's wrong, and what I can do to make my camera format and successfully use a SD card!
Thanks.
