One for Hefti
Posted 29/03/2010 - 11:30
Does the lens say "USSR" on it? It could be an Industar 50mm lens. Alternatively it could be a Leica! Does it fit on the Leica?
Early Zenits also used M39. The rub is that if it is a lens designed to work on the rangefinder, even if you get a M39->PK adaptor (available on ebay) you will not be able to focus the lens on infinity. If it is for the Zenit, you should have better luck.
We need a bit more info on the lens and the camera to be of more help.
K.
K.
Posted 29/03/2010 - 11:42
I dont know what camera it came from, it is unused in a plastic case with the lens screwed to the bottom, it has zelox writen on the lens.
Would it be any good for macro work it is non focus so would not be of much use unless it was used on bellows,
done a quick search on Ebay no adaptor is listed, thanks for that
Some zooms
https://pentaxphotogallery.com/artists/jack" target="_blank">
http://c759846.r46.cf2.rackcdn.com/img/black_link.jpg" alt="See my photos featured in the PENTAX Photogallery" />
Some zooms
Posted 29/03/2010 - 12:24
Posted 29/03/2010 - 12:31
Zelox appear to have made darkroom equipment so your original suggestion it is an enlarging lens seems likely. When you say "non focus" do you mean it doesn't have a focusing ring? If so, then the only way to use it sensibly would be on a bellows for macro work.
K.
K.
Posted 29/03/2010 - 12:36
Thanks kris & Garth I will get the adaptor but not being able to focus makes it difficult to use thank you.
ps should have thought about that before I posted
Posted 29/03/2010 - 13:53
It is indeed an enlarging lens by the sound of it. Useful for macro work on bellows but not for anything else really.
Get yourself a set of M42 bellows (the genuine Pentax ones are by far the nicest) and the M42-M39 adapter and you'll have the makings of a very nice macro set up.
Joining the Q
Posted 29/03/2010 - 14:49
Heft, I will see what other photographic equiptment this lady has, her late husband had a lot of pentax equiptment which was quite expensive, but had the eyes picked out of it, she said I was welcome to what was left.
thanks for the post.
ps She said his equiptment was insured for $30,000
Some zooms
Some zooms
adelaide
thank you.
Some zooms
