Old SLR lenses usage on a K-M
kenco
Posted 10/12/2009 - 21:13 Link
myself and my dad have recently bought a Pentax k-m and we have our old film SLR lenses they fit the k-m fine but i am having trouble getting the lenses to work i.e. actually take a picture do any of you guys use old lenses rather than the new digital auto focus jobbies? If so help would be much appreciated, I realise that the new lenses would be much better but for the time being I would like to use the old ones
and I would just like to say what a wonderful forum I’m sure I will be appearing often for help and advice and of course give advice where i can
Kenny
Clarky
Posted 10/12/2009 - 21:19 Link
Have you set the "allow use of aperture ring" in the customs settings to "permitted"
You haven't said exactly what the problem is, so I am assuming you can't get the shutter to fire. ??
Camera:|K-7|
kenco
Posted 10/12/2009 - 21:28 Link
Many thanks for your quick response
that is indeed the problem where abouts is the custom setting that i need to change (im probably having a man look)
Clarky
Posted 10/12/2009 - 21:40 Link
I don't have the K-M but I guess its the same as other Pentax DSLRs
Click on "menu" and you should see 4 tab menus across the top of the screen. "Custom settings" is usually the last tab, scoll through that menu until you find "Allow use of aperture ring" and then set it to "Permitted" Hope that helps.
Camera:|K-7|
kenco
Posted 10/12/2009 - 21:45 Link
Funny enough Clarky i was just about to respond to my own question i decided to have a womens look and found it all working now again many thanks
Clarky
Posted 10/12/2009 - 22:02 Link
No problem, what lens is it you are trying to use?? Does it have the "A" setting on the aperture ring. If you move it off the "A" it will cause the same problem as described above.
Camera:|K-7|
