Old flashes- question
Lukhash
Posted 03/11/2012 - 12:33 Link
Hi. I`ve got a chance to get Miranda 650 OM (Olympus) flash, and Cobra MD210 flash really cheap. I would like to use it wirelees with triggers,but don`t have a chance to check voltage of this flashes, and don`t want to burn my triggers. Any ideas if they`re safe ??
Lukhash
Posted 03/11/2012 - 12:50 Link
http://www.heritagecameras.co.uk/powerful-bounce-zoom-flash-for-olympus-om-fits-...
Found this It seems quit powerfull, and safe. And can get it for £8 so looks like a bargain
PeterKR
Posted 03/11/2012 - 16:47 Link
I posted a similar question earlier in the year about an old Miranda 450CD flashgun that I've had for 50 years !
You need to check the trigger voltage and MORE IMPORTANTLY the POLARITY !
I was given the followinh link, which is very helpful. If your Flash is not listed just click on the link about measuring the trigger voltage yourself (it is very easy)
http://www.botzilla.com/photo/strobeVolts.html
I found that whilst the trigger voltage on my flash was OK it was REVERSE POLARITY !
I have therefore not used mine !
Good luck
Edited by PeterKR: 03/11/2012 - 16:48
Pentaxophile
Posted 03/11/2012 - 20:26 Link
I've no idea how fussy flash triggers are, but old off-brand flashes really are two a penny - you might as well select ones you know are fairly reasonable. For a little more money you could also go for variable power units e.g. Minolta AF2000.
DaveHolmes
Posted 07/11/2012 - 19:11 Link
lgriffiths wrote:
Cactus V4 and V5 triggers will handle portable and studio strobes up to 300V (http://www.cactus-image.com/).
I have some cactus v4's I used with vivitar 283's (one of which is over 200V) they work fine. I've heard the cactus V5s are better.
^Everything he just said^ The cactus V5's act as a 'safe-sync' between flash and camera and the V4 receivers will handle old flashes with high voltages just fine...
To the OP... What triggers are you running? Should be able to get info on yongnuo (or any other brand) triggers on flickr-strobist group-forums fairly easily
Digital:
Flash:
Film:
