Oh, not him again!
Posted 01/12/2017 - 16:48
Aitch53 wrote:
One last thought, it strikes me as a shame that it’s so much easier and cheaper to produce big CMOS sensors compared with CCD, I suspect a big-CCD based camera would be quite impressive...
Hmm...I think a 645d is what you are looking for...
Regards, Philip
Posted 01/12/2017 - 16:50
smudge wrote:
Unfortunately, my kidneys are not in good enough condition for me to sell one to be able to afford such a beast...
Hmm...I think a 645d is what you are looking for...One last thought, it strikes me as a shame that it’s so much easier and cheaper to produce big CMOS sensors compared with CCD, I suspect a big-CCD based camera would be quite impressive...
SteveH!
I prefer 'unconventional'.
Posted 01/12/2017 - 18:40
You need better weather for the K10D and keep the ISO to 100 or 200 to avoid noise.
There's no difference between CMOS and CCD. It's the camera strap that makes the difference
Two Leica cameras compared
http://www.reddotforum.com/content/2015/02/the-great-debate-ccd-vs-cmos-part-1/
Posted 01/12/2017 - 19:27
I still have a pristine K10D available, along with an equally pristine K20D. They are in the Classified Ads section.
Posted 01/12/2017 - 19:47
Now he tells me!
SteveH!
Posted 01/12/2017 - 20:15
Posted 02/12/2017 - 08:15
stu62 wrote:
theres nowt wrong with the k10
and thats high iso 1600
I can see a lot of grain theres nowt wrong with the k10
Posted 02/12/2017 - 09:37
And I can hear a lot of noise!
Those colours are very appealing, there's no doubt about that.
Posted 02/12/2017 - 09:54
Posted 02/12/2017 - 21:20
Algernon wrote:
There's no difference between CMOS and CCD. --
Depends on the application. For true IR and NIR applications, CCD's outperform CMOS.There's no difference between CMOS and CCD. --
Posted 02/12/2017 - 23:34
Posted 03/12/2017 - 09:04
Just Combine the two
Chris
Posted 03/12/2017 - 19:40
Well, after a couple of minor panics, I've had a quick play and I quite like the results so far. They could be better - I need to spend more time getting it set up, but yeah, it's OK.
I've put a couple of shots on Flickr. All converted from RAW, as the way it's set was underexposing somewhat. Didn't help that it was rather a dull day. More will come - that's not a threat, by the way. Well, not quite...
The panics? Well, I thought there was a problem with the focusing, until I realised the dioptre setting on the viewfinder was at the wrong and and then I thought there was an internal problem - the Shake Reduction option was greyed out in the menu. Google soon reassured me on that one!
SteveH!
13 years
St Aines
A few months ago, due to a strange combination of events (boredom, the internet, a bet with myself and the smallest possible lottery win), I ended up the owner of a low-mileage N!k*n D80 with a N!kk*r AF-S DX 18-55mm f3.5-5.6G VR kit lens. I’ve censored the names for the more sensitive souls who like to pretend P3nt@x is the only DSLR manufacturer. Oops! Sorry about that, this censorship lark is a tad habit forming!
Anyway, I’ve used it for a couple of months and it’s pretty good for a ten year old, 10MP camera. The nice colour handling was one thing that stood out.
Then, by coincidence, I dug out my old Pentax 33LF (see the thread in the Your Photos sub-forum). Even fewer MP (3.5, iirc), but similar colours. Interesting….
So I did some checking. Both use CCD sensors, as opposed to CMOS. Mind you, so does the Olympus C-1 Zoom I got given, but that has only 1.5MP and really low ISO limit, so harder to tell! And the colour handling is apparently also down to the software used to convert the files to JPEG. A bit more checking. The last Pentax DSLR to use such a sensor was the K10D. Start the search! Found one going fairly cheap on the SRS site, with kit lens and a low shutter count. Out with the credit card...
Obviously I ordered at the wrong time (Black Friday/Cyber Monday/Techno Tuesday/Whatever Wednesday etc) as it took five days to turn up from SRS. It usually takes just a couple and I had assumed the worst - “one of the part-time staff went to get it from the store-room and accidentally dropped it in the vat of liquid nitrogen we keep there for no obvious reason, and it shattered!”, that class of thing. But it eventually arrived this afternoon and I guess they were just snowed under with orders for the sort of very expensive gear I can’t afford and my order got buried under those for K1s and so on. Oh well, c'est la vie, as we say down the ol' Frog and Trumpet.
So how do they compare? First impressions are as follows…
Both are ‘semi-pro’, which means both are well made and solid, and things like battery grips are available, assuming you can find them. They also both use re-chargeable batteries and SD cards, which makes life easier, not to mention cheaper. Both have image-stabilisation, just in different places.
The D80 is lighter and marginally better balanced, in my opinion. But ergonomics are a personal matter and it is a close-run thing.
The K10D is noticably heavier (body at 793g as opposed to 668g, though they both have heavyish kit lenses, which evens things up a bit), which affects the balance a bit less than I expected, but could be relevant if I was carrying it about a lot.
Over the next couple of days, I’ll get it set up, get the feel of it and try it out on my usual test subjects, and see how it compares that way – expect some of my more tedious pictures to turn up early next week.
All in all, I suspect they will get an equal-ish amount of use – well, the new one is a Pentax and can probably expect a bit more work!
