Not quite totally OT. External disk drive conundrum
George Lazarette
Posted 07/03/2008 - 19:24 Link
This question relates to my computer, the home of my digital pictures, and therefore vaguely relevant.
I have two Porsche-design external USB2 hard drives, purchased together. Inside they are Toshibas.
One works fine; but the other, whenever connected to a computer, causes a little box to appear saying: This drive would work better if connected to a USB2 port.
Of course, it always IS connected to a USB2 port.
Any ideas?
Galoot
Posted 07/03/2008 - 19:58 Link
Get an Apple Mac ?
Galoot
Posted 07/03/2008 - 20:03 Link
Sorry, couldn't resist it
George Lazarette
Posted 07/03/2008 - 20:11 Link
What makes you think I am not using it on a Mac?
mikew
Posted 07/03/2008 - 20:23 Link
Have you tried it on another USB port?
Does the drive have any jumpers or dip switrched that configure it?
Daniel Bridge
Posted 07/03/2008 - 20:48 Link
I'm assuming this has recently occured and the drives are out of warranty.
Try a different cable? Make sure it's a USB2 one. :
Dan
Mongoose
Posted 07/03/2008 - 21:52 Link
Swap the cables and see if the problem transfers to the other drive.
USB 2.0 cables are largely marketing spin, but occasionally you come across a boosted cable (usually long ones) which will only do USB 1.1
but it does help
Galoot
Posted 07/03/2008 - 22:30 Link
You wouldn't be having a problem if you had the Mac ?
George Lazarette
Posted 07/03/2008 - 23:10 Link
Thanks for the suggestions.
There are no switches or buttons for configuration, and I have tried several different ports. What I haven't tried is a different cable, so I'll give that a go.
George Lazarette
Posted 07/03/2008 - 23:24 Link
Bizarre. Same cable, same port. One machine is USB2, the other is not.
So perhaps they can be configured if I remove the case, or perhaps one is dud, or perhaps I have been sold different drives in identical cases.
Bother!
Daniel Bridge
Posted 07/03/2008 - 23:31 Link
Don't think the drive would be cause, as any drive should be more than quick enough for USB2. Might be a setting on/in the case.
So were these off the back of a lorry? Can't you get a replacement? Sounds like they're new (to you).
Dan
George Lazarette
Posted 07/03/2008 - 23:42 Link
Dan
Back of a lorry? How dare you, sir? That's two insults in a week, Bridge; your card is marked.
They were purchased new from Insight 18 months ago, so I don't think they are likely to be sub-standard.
I put up with it before because my old computer only had two USB2 ports, and I assumed I was always selecting a USB1 port. Now, my super-fast new machine is all-USB2, so I need to find an answer.
Daniel Bridge
Posted 08/03/2008 - 00:00 Link
I humbly seek your exculpation.
Dan
pentaxian450
Posted 08/03/2008 - 13:19 Link
Did you try sending an e-mail to the manufacturer/distributor explaining the problem to see if they have a solution? This is what I would have done first!
Don
Posted 08/03/2008 - 13:33 Link
new doesn't always mean free from manufacturing defects or damages.
I had a simillar problem with a firewire case I installed on my robot....
I believe I narrowed the problem down to a static discharge damaging the circiuts inside the case during install....in other words, I broke it.
