Not enough power
Posted 27/06/2011 - 02:54
I think if you needed that much power, you had the wrong lighting set up for the subject you wanted to photograph. Generally, the umbrella is close enough to the subject that you don't need such power, unless you're trying to photograph an Airbus A-380 in a studio. And then, one flash and one umbrella would be unsuitable...Maybe if we knew what you were trying to photograph, we could come up with an alternative solution...
Posted 27/06/2011 - 09:31
It was 2 guitarists in a room full of instuments... Flash bounced off the ceiling was fine at 1/1 ISO100 but lost a lot of power (2 stops) when using the reflective... I wanted an aperture of f8 so had to bump the ISO up to 400...
If I'd've wanted f11 with the one light I'd've had to ISO800 witch would have caused more work post...
As it was I got ISO200 at f8 but tying the YN560 to the Vivitar gun...
In a more normal portrait situation I'd've had the brolly much closer to the subjects but in the space used that just wasn't an option as the scene was also crucial to what they wanted...
I'm the first to admit I have a lot to learn but I consistantly wish I had a little bit more juice in terms of light...
Dave
Dave
Digital:
Flash:
Film:
Digital:
Flash:
Film:
Posted 27/06/2011 - 10:31
Can't remember which - Benvie, Noton or Hoddinott - but one of these guys uses battery 'studio' kit for field photography. Might be worth researching?
If I can I'll scan through my various books and see if I can find the references/kit.
Posted 27/06/2011 - 10:45
I've got a Metz 50MZ5 (GN of 70 @ 105mm) which is still portable, and kicks out a painful amount of light (It's looking for a new home )
If you want to retain any room 'ambience', then personally I'd look at other methods rather than trying to get a portable 'sun'
But ISO800 shouldn't involve much post production work... I now regularly use ISO3200 on the K-5 and it's no bother at all when working in RAW with Lightroom 3
Posted 27/06/2011 - 15:16
Most studio flash heads are portable. OK you cant stuff them in your bag but you're taking stands and brollies! Calumet own brand heads have battery options as do the far more expensive Bowens and Profoto ones.
You'll have to do your own searching but I'd check to see if Quantum do a battery option for your flash. It wont be cheap but power/quality/reliability never is. My Quantum set up with my very ancient Pentax flashguns delivers 1000 flashes per charge and re-cycle times that can allow 3 shots per second.
These days, I take GNs with a very large pinch of salt, there are far too many variables which is why pro studio heads rarely talk about them.
Posted 04/07/2011 - 20:10
Have a look for the Metz 45CL-1 (not the CT-1 as some of those have trigger voltages which can fry DSLRs). Plenty of power, has a bounce/swivel head, and can be found used for £30. Might need a new battery pack but mine seems ok so far on the original Nicads (included a charger). They also made diffuser and telephoto attachments, the diffuser essentially being a pale plastic panel and bracket which bounce the flash forwards after you point it upward.
Posted 05/07/2011 - 01:37
Or increase the exposure time? Am I missing something?I wanted an aperture of f8 so had to bump the ISO up to 400.
Another solution is a second off-camera flash controlled by radio trigger. Not an expert but it's worked for me.
Posted 05/07/2011 - 02:13
Elinchrom quadra/ranger are an expensive option... but here's the big question..
WTH are you doing? need more info.
When shooting with flash, you ALWAYS have two light sources ambient and flash.
First you choose which will be your MAIN light and which will be your FILL light...
USUALLY I decide to use a flash for main on my subject, and get the light as close to my subject as possible, then use the ambient as fill. often this technique involves setting up a tripod. Your tripod is like having thousands of watt seconds of lighting units for HUGE areas.... you set that exposure (I often under expose it slightly) FIRST for your ambient, then set your FLASH for your subject.
So I'd say use the tripod to get a base exposure, then add some flash to light your subjects.
I've shot portraits at iso 800, f8, 1/8 sec with a brollie mounted af 360 fgz with power to spare....
Posted 05/07/2011 - 02:14
rparmar wrote:
Increasing the exposure time will only affect the parts of the photo lit by ambient light. The subject is presumably lit by the flash, so shutter speed has no effect.
Or increase the exposure time? Am I missing something?.I wanted an aperture of f8 so had to bump the ISO up to 400.
Tim
Posted 05/07/2011 - 02:18
thoughton wrote:
exactly what he needs to do, if he doesn't want to spend three grand on lighting.rparmar wrote:
Increasing the exposure time will only affect the parts of the photo lit by ambient light. The subject is presumably lit by the flash, so shutter speed has no effect.DaveHolmes wrote:
if he has to skip the brollie and shoot with hard light, he can always soften parts in post.
Posted 05/07/2011 - 04:38
Unless he's shooting in the dark, the subject is presumably lit by both.
Posted 05/07/2011 - 11:33
Hmm, are you pulling my leg?
Tim
Posted 08/07/2011 - 17:56
Agreed (I've got two), but if you need even more the Metz 60 is like a cheap portable sun...
ME, Z-1P, K5, LX, ZX-5, 67ii, LX5, RX100
Bradford
I really love the portability of hotshoe flashguns but think that at some point I may need a more powerful flash...
Does anyone have any ideas on a suitable (budget) studio strobe with a powerpack for portability... ?
To be honest I'm not sure what to look at... Zack Arias's 'OneLight' video suggests AlienBees but they're not availible from any UK suppliers... What's the British alternative?
Dave
Digital:
Flash:
Film:
