None dirty word astro!
Posted 13/08/2024 - 14:30
Next stop, dark matter? Then Spad into space clutching a monster telescope??
How do you cool it to -20 C? Dry ice? Sooper-dooper refridgerator?
I hope you've kept a Pentax body or two for non-astro photography!
Posted 13/08/2024 - 16:40
No idea how it does but it does it!! In the actually camera controls it goes down to -40!!
I still have my K3 and K20d IR. I am hoping to get a K1 next year.
Posted 13/08/2024 - 19:27
You tickled my curiosity so I had to find out. It's thermo-electric cooling (TLC). Put two different materials in contact, pass a direct current across the junction and one side heats up, the other cools down. Dispose of heat to atmosphere and you've got a solid-state fridge. That's the principle, anyway, turning it into a practical gizmo seems to be a bit tricky.
From what I can understand of the principle, it's temperature difference that counts so the temperature you dial in might be the difference with respect to ambient rather than the actual temperature of the sensor - perhaps worth checking.
Posted 13/08/2024 - 23:16
That's a WOW image!!!!
Posted 13/08/2024 - 23:40
Lubbyman wrote:
[quote:3496ace15f="Spad"]
That is correct...
If the ambient temp is 25, the the camera will cool it by 35 degrees to get it to -10. If the cameras max temp (for cooling purposes) is say 30. Then it will only be able to cool it to -5. Mine is cable as of 45....
Thank you!
Posted 14/08/2024 - 18:58 - Helpful Comment
Your Astro shots really are of the highest calibre
Posted 15/08/2024 - 02:01
Thank you!
Posted 15/08/2024 - 13:54
As a matter of interest, what is the object in the image?
If I had to guess, I'd say it was the Spud Nebula.
SteveH!
I prefer 'unconventional'.
Posted 15/08/2024 - 20:22
It is NGC6888 Crescent Nebula in the constellation of Cygnus. It's 5000 lightyears from earth, that is 29,500 Trillion miles...
Posted 17/08/2024 - 11:12
Thank you.
SteveH!
Instead this was taken with a cooled Deep Space Object Dedicated Camera, a ZWO ASI183MC Pro. It has a 1in 4/3 sensor at 20mp and 2.4um pixel size. I traded in a couple of Pentax bodies I haven't used in months, and an unused EQ mount.... because for what they are, they are not cheap!
But they are cooled.... really cooled... the sensor can be cooled down to -20°. This makes them extraordinarily sensitive, as well as reducing noise. The advantage of this is (apart from the fore mentioned ones), unlike a DSLR, in which you have to allow the sensor to cool (usually half the time of the exposure) between shots. With this one, you don't. That means you can shoot half as many light frames again.
So.... as you will probably figure out from now on the vast majority of images I'll show you guys, will be taken with this camera!
Enough waffle now....
