Noise Removal Software
petemasty
Posted 06/05/2009 - 11:56 Link
Is it worth getting a bespoke Noise Removal Software package? I use PSP and obviously it has noise removal on it. But, are these bespoke pacakges better?
Pete M
My Flickr
ttk
Posted 06/05/2009 - 12:40 Link
I use Ninja myself if needed of cause
Tel,
piotro
Posted 06/05/2009 - 12:53 Link
Or NeatImage, I think Ninja and Neat are the two top and comparable noise removal software.
petemasty
Posted 06/05/2009 - 13:00 Link
Do you think they are necessary knowing most (if not all packages) have noise removal already built in?
Pete M
My Flickr
JonSchick
Posted 06/05/2009 - 14:13 Link
I use Neat Image, which is free as a standalone for JPEG only, but I paid for the Photoshop plug in which makes things more seamless, and works on other file types.
I think programs like Neat Image, Noise Ninja etc tend to be more sensitive and controllable than the noise removal options build into applications such as Photoshop - and when I've seen comparison tests they've always come out best.
Although it's not necessary to use them terribly much with newer dSLRs unless you're obsessed about noise (a la DePressing Review for example), it's still nice to have on occasion, and they can be great with compact cams too - sometimes required even for ISO80 from my G10 if I use RAW.
Jon
Some occasional random stuff at The Photographers Block: link
piotro
Posted 06/05/2009 - 14:35 Link
I use NeatImage sometimes, 99% of this "sometimes" is when I'm submitting photo to some photo galleries with screening (these guys usually don't like noise), and photo was taken on high ISO, shows some visible noise.
Therefore I'm not using noise removal in camera or in other software.
Surely you have a much more control over the process of cleaning photo when using that software, often even at default values effect is very good, without the need to tune it (algorithm may be more advanced as well).
On the other hand noise removal build in UFRaw is not bad, sometimes I tend to use it a bit and skip the NeatImage (I use UFRaw to work on RAW files).
Edited by piotro: 06/05/2009 - 14:40
misiek_knm
Posted 06/05/2009 - 21:51 Link
Is there any good one for Linux (Debian in particular, but not necessary)? When 'developing' from DNG I usually use RawTherapee, which has some noise reduction filters, but I'm not very satisfied with them.
Kind regards,
Michal R. Hoffmann
Greytop
Posted 06/05/2009 - 22:08 Link
I find Helicon Filter http://www.heliconsoft.com/heliconfilter.html pretty good, I've had it years since Beta and it has developed into quite a capable package.
Regards Huw
flickr
Edited by Greytop: 06/05/2009 - 22:08
beachboy2
Posted 08/05/2009 - 17:02 Link
I use Noise Ninja and its great.
bb2
K5, K20D, Bigma, Sigma EX 105, Sigma EX 10-20, Sigma EX 28-70 F2.8, Sigma Ex 1.4TC,
Pentax 135 F3.5, Pentax 30mm F2.8 , Pentax 50mm F1.7, Pentax 55mm F1.8,
Super Taks: 35mm F3.5, 50mm F1.4, 135mm F3.5, 200mm F4
Vivitar TX 200mm F3.5,Vivitar (Komine)135mm f2.8, Vivitar 2X TC, Vivitar T4 400mm F6.3
Tamron SP 35-80,80-210 F3.8, Helios 44M, Mir 1B 37mm F2.8, Jupiter 9 85mm F2, Chinon 28mm F2.8, 3M-5A 500mm F8 etc etc
Malo1961
Posted 08/05/2009 - 17:44 Link
Noise Ninja does. Look here beneath this heading. Noise Ninja 2.2.0 standalone software
Hope it helps,
Martin.
Best regards,
Martin.
misiek_knm
Posted 09/05/2009 - 21:25 Link
Thanks Martin, I'll give it a try - they say it's for x86, but maybe it will work on amd64 (which I have) as well.
Kind regards,
Michal R. Hoffmann
