no budget tele question
Posted 06/01/2008 - 22:05
For what you'd have to spend on a half decent converter you'd be far better off looking for a second-hand longer lens, the Pentax 80-320 for instance, also have you considered manual focus? you should be able to find a 400mm K mount or even KA mount for a reasonable amount.
There are plenty of third party KA and KAF 70-300 available on ebay
Posted 06/01/2008 - 22:18
Thanks for that !
Point taken about TC cost I'll look out for that 80-320.
Should have mentioned Ebay is out as I haven't got a credit card
The market in NZ is very small though prices of second hand stuff seems quite good.
A 400 m42 came up a while ago but I really want stop down metering.
Quite happy to focus manually.
cheers
cheers
K-1 K-01 Q-7
some len
Close to the Edge
Down by the River
some len
Close to the Edge
Down by the River
Posted 06/01/2008 - 22:40
Also consider a new Tamron or Sigma 70-300mm - which are sometimes cheaper than used Pentax 80-320s and similar.
I don't know if it's the same in NZ, but a UK PayPal account can be linked directly to a bank account instead of (or as well as) a credit or debit card.
~Pete
Posted 07/01/2008 - 08:10
I tend to use my Pentax FAJ 75 - 300mm quite a lot.
I love this lens - and it is cheap. Some don't love it, but my results are pretty good.
If you follow the link below - and watch the nature thread, almost all shots are done with this lens.
I think its around 100 £ from new......a bit cheaper second hand.
If you need a faster lens - don't use it. I only use it for outdoor shots, and the light is quite often enough to have a very fast shutterspeed.
Posted 07/01/2008 - 13:41
as a point of interest, most m42 are actually easier to use on the DSLRs than M series. This is because you get the little "A/M" switch which allows you to manually stop down the lens to shooting aperture.
Therefore, you can use AV mode at all apertures instead of just wide open as with your M series 200 F4.
but it does help
but it does help
Posted 07/01/2008 - 20:30
Thanks Guys, very helpful !
Mongoose I have the adapter and a few M42 lenses.
Took me a while to figure out they were not stopping down to take the shot
K-1 K-01 Q-7
some len
Close to the Edge
Down by the River
some len
Close to the Edge
Down by the River
Posted 07/01/2008 - 21:10
no they don't, but neither do M series lenses in AV mode. The M42 lenses have the advantage that you can force them to stop down to shooting aperture. The camera meters for the light entering the lens (which is now stopped down) and AV mode works.
With an M series or earlier K mount lens, the camera simply doesn't fire the stop down actuator so it's always wide open in AV mode no matter what the aperture ring is set to.
I've had some pretty reasonable results with my M200 F4 and a Tokina 7 element 2x converter. Since the lens is only an M, you don't need auto or AF pass throughs on the converter and should be able to pick one up quite reasonably. My M 200 F4 + 2x converter is better than my FA 80-320 provided there's enough light.
but it does help
but it does help
Posted 07/01/2008 - 22:14
Thats interesting to hear about the 200 and TC
I usually shoot in manual with these lenses . I hit the AEL button to get stop down metering in the M lens then go from there.
K-1 K-01 Q-7
some len
Close to the Edge
Down by the River
some len
Close to the Edge
Down by the River
Posted 08/01/2008 - 21:42
I use a Tamron 70-300 which I get pretty decent results with on my K100D. If you hunt around they are <£90. The advantage of this over many of the older lenses is that it is light and has a 1:2 macro.
Donut
Donut
Posted 08/01/2008 - 22:12
The Tamron 70-300 macro is $245 here which is about the same as UK.Pretty blinking cheap. Hasn't it got CA issues though ? I thought the sigma was better ?
K-1 K-01 Q-7
some len
Close to the Edge
Down by the River
some len
Close to the Edge
Down by the River
Posted 08/01/2008 - 22:37
I just located a Takumar x2 teleconverter (Pka) for equivalent of 30 quid.
Might be the go for my 200M in the meantime ?
cheers
Pete
cheers
Pete
K-1 K-01 Q-7
some len
Close to the Edge
Down by the River
some len
Close to the Edge
Down by the River
Posted 09/01/2008 - 00:45
I don't think you'll find there's much (if anything) between them. I've got the Tamron and as long as you work within its limitations (a bit soft wide open, not very good at 300mm unless stopped down quite a bit) it's actually not a bad lens. I don't have much use for a tele - maybe only 7 or 8 outings a year - so I didn't want to spend a lot of money on one and the Tamron has actually been much better than I imagined it would be. People who own the Sigma will tell similar stories so your best bet would be to go for the one that's in stock and/or at the better price.The Tamron 70-300 macro is $245 here which is about the same as UK.Pretty blinking cheap. Hasn't it got CA issues though ? I thought the sigma was better ?
There's a good review of the Tamron here: http://www.photozone.de/8Reviews/lenses/tamron_70300_456_pentax/index.htm
and the Sigma here, albeit in Canon fit: http://www.photozone.de/8Reviews/lenses/sigma_70300_456/index.htm
I don't think you'll really go far wrong with either
Joining the Q
Posted 11/01/2008 - 20:30
I found a Sigma 400/5.6 MF with a KA mount for £ ~35 on local ebay in Sweden. Works well, some CA but its dwarf compare to my old Pentax K400/5.6.For what you'd have to spend on a half decent converter you'd be far better off looking for a second-hand longer lens, the Pentax 80-320 for instance, also have you considered manual focus? you should be able to find a 400mm K mount or even KA mount for a reasonable amount.
K10D|K20D|K-3| AF lenses| Sigma 10-20 F4.5-5.6|DA14| Sigma 18-50EX macro|FA20 F2.8|FA35 F2.0|FA50 1.4 & 2.8 macro|Sigma 70 macro| FA135| F70-210| F300 F4.5|Tokina SD 400 F5.6 AT-X
20 years
Whanganui New Zealand
I have the K100D. My longest lens is an M 200mm f4 and I really like it. Would the most economical way to get more length be a teleconverter ?
Which one would best suit this lens ? would I have to stop down much ?
cheers
Pete
some len
Close to the Edge
Down by the River
