Neewer AD200 studio head plus accessories
cardiffgareth
Posted 18/11/2023 - 20:48 Link
Here is my Neewer AD200 battery studio flash.
Comes supplied with everything from new, such as the bare bulb attachment and the fresnel head attachment. Included also are the accessories:
AD-S7 umbrella style softbox with the beauty dish attachment and grid pattern for directional light.
Neewer BD-07 Magnetic barn doors.
Godox Pro Bowen S type light stand bracket.
All works as it should, I'm selling to fund a new mains powered flash head. I can supply further images of the flash head for those who would like to see it from all angles, showing off the overall condition.
I'm keeping the trigger for the new studio heads when they come sorry.
Price is £250 Inc postage to UK addresses
Advertised elsewhere also
Posted 19/11/2023 - 00:17 - Helpful Comment Link
I can't even make basic flash work properly!
My page on Photocrowd
cardiffgareth
Posted 19/11/2023 - 09:29 Link
Ha! This is a easy peasy flash! You can use it like a normal flash with a guide number of 60, or, you can change the head for the bare bulb option if you're shooting it through a softbox, brolly etc.
When you have the correct trigger, you can adjust the power from that so you don't need to be messing with the flash head, of its in a brolly for instance.
I mainly used it for portraits both indoors and outside where I needed the power to balance the sunlight.
On the flash you can select P-TTL, HSS or manual mode (which is where I've always used it)
If you have the trigger for a different brand, well the flash can be used the same so Fuji, Canon or Nikon TTL.
You can also set the flash to fire on a certain group, so say you had a few of these, or other Godox flashes, this could be set to sat channel one where its 1/8th power and the others set to channel 2 where they're set at maybe 1/2 power.
This is the Pentax trigger but you can buy a Godox X1 trigger for Canon which won't allow TTL so manual only and then it's just a 'dumb' trigger which is cheaper.
Edited by cardiffgareth: 19/11/2023 - 09:36
cardiffgareth
Posted 19/11/2023 - 20:51 Link
Sold elsewhere
