Need immediate help please
Posted 09/07/2009 - 15:47
I'm sure Chris will be happy to post one to you in Sweden, he posted a lens cap to me in Australia and Sweden is just around the corner
Camera:|K-7|
Posted 09/07/2009 - 15:53
Not all the M42 adapters allow infinity focus, so the original Pentax one is the best option, for all the reasons stated.
Posted 09/07/2009 - 16:23
I've been using a half dozen Roxsen M42 adapters for several years. They allow infinity focus. The first thing I did was Locktite the screw that holds the spring. I realise most folks won't have the stuff around. But a lot of auto garages and machine shops do. I doubt they'd charge much for a drop of Locktite.
They've always mounted well and are smooth as my original adapters.
Posted 09/07/2009 - 16:56
polchraine wrote:
Yes, Chris is a member and posted today about arrival of the K7.
Did you mention you are a forum member? You may not get free postage to Sweden but it does let him know who advised you to call him
In my mail to them I mentioned I were on this forum and got the tip from here.Yes, Chris is a member and posted today about arrival of the K7.
Maby I should send him a mail to his forum profile?
http://www.drakfoto.se
_________________________________________
Pentax K10D (soon to be K7 I hope)
Pentax SMCP-FA 50mm f/1.4
Sigma 17-70/2,8-4,5 DC Macro
Karl Zeiss Jena S 135mm 3.5
MC Zenitar 2.8 16mm Fish Eye
Pentax-M SMC 28mm 2.8
Asahi Pentax 500mm 8.0
Posted 09/07/2009 - 18:17
Yes Chris is a member.
As for cheap adaptors, some have a flange on that stops the lens sitting flush on the camera mount, result, loss of infinity focus.
I have one which I use for a CZJ 35mm for close up stuff, totally useless beyond 3 metres.
Cheers, HG
PPG entries.
PPG entries.
Posted 09/07/2009 - 18:22
You will be fine ... He has probably read this thread too!
Posted 09/07/2009 - 23:21
shim wrote:
I would think all M42 to K adapters support infinity focus.
shim
No. There are a lot of adapters from the Far East which have a flange that sits between the lens and the camera, thus preventing infinity focus and (on the positive side) allowing you to focus closer.I would think all M42 to K adapters support infinity focus.
shim
A proper adapter has no flange, and sits within the throat of the lens mount - and flush with it.
Posted 11/07/2009 - 19:56
I've just payed the adapter + shipping costs to Sweden!
It ended up alot cheaper than I thought, £24.99.
In Sweden the very same adapter costs around £65, INSANE!
Thank you all for you help and information.
/Magnus
/Magnus
Posted 14/07/2009 - 19:07
Is this the place to ask about lenses?
My K200D is supposed to be compatible with the old lenses I used on my SLRs.
So I must be doing something wrong, because I can't make the camera take a picture, when I have a manual focus lens on it. Is there something I have to set on the camera?
I suppose someone will say RT Flippin' M, but I have, and can't find Manual lenses mentioned. Does anyone know how this goes?
Cheers folks
John
Cheers folks
John
If you wish to make a small fortune out of photography, it's a good idea to start with a large fortune.
Posted 14/07/2009 - 19:25
RTFM! Seriously, there is a bit in it about "Using aperture ring" in one of the menus. On the K10D it's the custom menu.
Posted 14/07/2009 - 20:03
Thanks George!
Yes I have read the manual, but I don't read French too well!
I have a disc manual in Brit-speak, but the page numbering system is non existent! I'll search for the phrase. Aperture ring..
Let you know how I get on..
Thanks my friend.
John
Thanks my friend.
John
Posted 14/07/2009 - 20:10
I think it's the same for the K200D as the K10D; in the Custom Menu find "Use of Aperture Ring" and change the setting to "Permitted".
Don't forget the lenses only work in (M)anual mode (with stop-down metering) and (Av)perture Priority (wide open only). The camera and the EXIF data will always show the aperture as being "F--" so don't let that throw you.
Joining the Q
Posted 14/07/2009 - 20:11
I managed to find it under 'Aperture Ring'. I was looking for manual lens!
There you go!
Thanks George.
Thanks Hefty... I found that setting too. No problems as of now! Says he hopefully!
regards
John
There you go!
Thanks George.
regards
John
20 years
LHR/ABZ INV/OSL/ZRH/LAX SNA/SEA/YUL +++
