Need a little help with CS2
Steveninwyoming
Posted 03/03/2010 - 23:27 Link
Is it possible with photoshop CS2 to process a batch of JPEG files. I need to resize to make uploading faster. I can do it one at time, but that is gonna take all day to "Getter Done".
Thanks, Steven
Steveninwyoming
Posted 03/03/2010 - 23:45 Link
Thanks Gareth, I'll check in tomorrow.
Steven
hefty1
Posted 04/03/2010 - 00:05 Link
I don't have CS2, but Photoshop from V5 onwards supports "actions". You'll find a panel for them with a set of controls that look like those on a tape recorder - you basically press "record" (the circle), open / resize / save a file, then press "stop" (the square).
Then point it at the next file(s) and press "play" (arrow) - it'll just go through the same motions and you can record as many or few steps as you like (adding sharpening possibly or raising contrast +1 or whatever).
There probably is a dedicated batch processor somewhere in CS2 but I've never upgraded that far so I haven't used it.
Joining the Q
Anvh
Posted 04/03/2010 - 00:13 Link
Is it only resizing?
I'm working from CS4 now but the CS2 looks quite like CS4 out of memory so try to follow.
Open CS2.
Then go to File > Scripts > Image Processor that's what you want
You can also say in that window (Image Processor) that it must follow an action.
Hefty now you know it too
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 04/03/2010 - 00:13
hefty1
Posted 04/03/2010 - 00:22 Link
I do
Although as I can't see myself upgrading any time soon (and I have dozens of PS5 actions already in use) I can't promise I'll remember it for too long...
Joining the Q
Anvh
Posted 04/03/2010 - 01:15 Link
Ah yes you're using PS5, forgot that.
I only know Photoshop up to version 7, the rest is before my time.
Stefan
K10D, K5
AF-540FGZ
Steveninwyoming
Posted 04/03/2010 - 13:52 Link
Thanks for all that info guys. I just resized 25 images just under 2 min.
Now how do I get a water mark on them?
Steven
Anvh
Posted 04/03/2010 - 14:22 Link
Make it into an action.
Simply make a logo or something else, let it upload that in a layer on top and set the Layer blending option to "screen" it will blend into the image or try out other blending modes to see what you like.
You can record what you do in an action and then when converting them to a lower size you can let the program preform the action automaticly.
Stefan
K10D, K5
AF-540FGZ
Anvh
Posted 04/03/2010 - 20:30 Link
For the watermarking link
Stefan
K10D, K5
AF-540FGZ
Anvh
Posted 05/03/2010 - 15:20 Link
I've no idea if you can link an action to a key shortcut.
You can simply "play" the action through the action tab, it will then do his thing.
Well just looked into the shortcut menu, you can not have an action under a key but you can have the function "play" from the action tab under a key. If you make sure you've selected the right action you can press the key and it will preform that action.
That's the best I can offer.
Stefan
K10D, K5
AF-540FGZ
Anvh
Posted 05/03/2010 - 18:51 Link
Oh yes indeed, thank you for letting me (us) know
I've an action I do 90% of the time so that could be handy.
You should be able to resize the watermark to a percentage of the photo, that way it should work better in an action.
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 05/03/2010 - 18:53
Darkmunk
Posted 05/03/2010 - 19:30 Link
I love the fact that I just keep on learning stuff
'File - Scripts'.... how did I keep missing that? I go to 'Automate' all the time, in exactly the same place
Anvh
Posted 05/03/2010 - 19:33 Link
Probably because of the user interface, it's really not beginners friendly, I believe they are tackling some if it with CS5.
Stefan
K10D, K5
AF-540FGZ
Darkmunk
Posted 05/03/2010 - 19:37 Link
No, the last thing I want is another change for the sake of it
Been using PS since V2.5 - I just get stuck in my ways It's good to see how other people do things. I used to learn loads from looking over my student's shoulders when I was 'teaching' them! ha ha.
Anvh
Posted 05/03/2010 - 19:45 Link
From what I've seen they are going to bring more options under tools themselves instead of hiding them in the menu.
For example when you want to straighten a photo, you get the ruler tool draw the line go in the menu and select straighten. With CS5 they have make a button "straighten" that appears in the tools options when you select that tool. Such sort things.
I also finally found out where most is but bringing things closer to the user is not a bad thing in my eyes if it makes things easier and faster. But I wouldn't like it if they mess up the menus
When is CS5 coming, I've heard April somewhere but aint sure?
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 05/03/2010 - 19:46
