nearly went in the bin!
Posted 13/06/2023 - 19:49
And what a difference! Creating drama out of a molehill (a slight misquote I think!).
You could use Photoshop's new AI tool to eliminate the gentleman, or replace him with an alternative being. Indeed, you could add a light in the lamp, a lady (of high morals, of course) in the window....
Which raises the question of how far we should go with AI? My thought is that it's OK to take out - we do this with the clone tool - but adding in something from someone else's picture library is another kettle of fish.
Posted 14/06/2023 - 00:18
Definitely throw some more into the bin if it gets the same same results!
Worcestershire
It was only after I'd added another similar image to the "your photos" section and someone had pointed out that the arch of light at the top of the steps was a bit too bright that I decided to take another look at this image. It didn't look great in colour, it had areas that were too dark and others too bright and the composition wasn't quite as good as I'd "seen" at the time of taking, so I wasn't sure it would be worth the effort - but I gave it a go anyway.
In PP, after converting to Mono and setting the contrast up a bit, I used a graduated filter to bring down the highlights on the wall at the right, adjusted the shadows/highlights and blacks and whites and for the composition I cropped out the small area that showed overblown sky and brought in the two sides to ensure the handrails touched the bottom corners. The image transformed from this....
...to this...
The moral of the story is, I think, don't be too quick to use the delete button when sorting through the results of your outings
