ND's and CPol's
Posted 18/04/2007 - 20:14
Yes. In the sense that you could attach a hose-pipe to your nose in order to emulate an elephant.
Simpler to buy a ND filter. Or three.
Posted 18/04/2007 - 20:17
They would be very dark! Polarising filters alter colour too, ND's are designed to have minimal impact on colour. You might get some strange effects from the polarisers as they rotate and go into "extinction" (total opacity)
Posted 18/04/2007 - 20:32
Yes. In the sense that you could attach a hose-pipe to your nose in order to emulate an elephant.G
George - it must be the air in the Isle Of Man Yes. In the sense that you could attach a hose-pipe to your nose in order to emulate an elephant.G
Posted 18/04/2007 - 20:39
We don't have air. We have hundred mile an hour pure ozone.George Lazarette wrote:
Posted 18/04/2007 - 20:43
Since I own a CP already and am getting a bigger one for my 16-45mm, I will already own two of them.Simpler to buy a ND filter. Or three.
So in my case it's not simpler...
And no, I haven't forgotten about the stepping rings...
And my understanding was that when a CP is oriented a certain way, it has no effect whatsoever other than to darken the image the same way an ND2 would. So one would conceivably be able to orient the two CP's wrt one another to achieve the correct/desired "darkness", and then orient the assembly wrt the sun in order to achieve the desired effect (or lack thereof) on the scene. :
Yes?
No?
Three bags full?
Posted 18/04/2007 - 20:44
George,
I could do with a few bottles of that right now.
Posted 18/04/2007 - 21:23
I'm afraid in the vast majority of cases this can't happen. And my understanding was that when a CP is oriented a certain way, it has no effect whatsoever other than to darken the image the same way an ND2 would.
some physics -For the purposes of a polarising filter, light travels as a transverse wave. When these waves (from the sun) hit a surface the angle of particle oscillations that make up the wave changes, and changes differently for each surface/angle of surface. A polarising filter works by only letting through light waves in one plane of oscillation. i.e it'll make the scene darker, but have a different (sometimes undesirable) effect on each part of the scene.
Posted 18/04/2007 - 21:36
Yes?
No?
Three bags full?
Yes?
No?
Three bags full?
An ND filter reduces all light passing through it. A polariser, on the other hand, only cuts light in a particular plane, and has a very different effect. It is most well-known for cutting reflections from water, and darkening skies whilst leaving the brightness of clouds unaffected.
In both these cases, an ND filter would simply darken the scene.
They are totally different things.
Posted 18/04/2007 - 22:28
RTFL@ George
The 2x polariser trick only works if at least one is a linear polariser. Two circular polarisers will do almost nowt
ND filters & ND grads are easy enough to come by... somewhere like Speedgraphic or SRB Film are good places to start. Or search out a second hand camera place. Cokin A filters are generally very easy to find and cheap.
Posted 18/04/2007 - 23:23
I shall experiment and advise findings... eventually...
Thanks all
Thanks all
Posted 19/04/2007 - 05:24
HAHAHA Yes. In the sense that you could attach a hose-pipe to your nose in order to emulate an elephant.
VERY funny George. (sorry for the delayed comment but I'm almost half a world away from you)
At first I thought you were joking but obviously IT WORKS!! Do you think this combination of Linear and Circular would do the trick?
20 years
